Leaky fuel tank
Leaky fuel tank
Guys, so last weekend at OC cruise my fuel tank sprung a leak. I took it to the dealership and they said it was not caused by the fuel module recall. They said the driveshaft had rubbed on the heat shield and rubbed a hole in the tank. It's an 07 Ctsv. Has anyone seen this? Can I patch the tank? They want 1900 for a tank and to install. Will a CTS tank fit or is it different from a CTSV?
Wow, this is new. And I'm not sure how its possible. For 1900$ you could have a whole new fuel system capable of 1000+hp .....so I would tell the dealer to off. Not sure about the tank though, I can imagine they are the same as a base cts but don't know for sure. Slide under there and snap a few pics. Or ask the dealership mechanic to if its still over there. Could always go fuel cell in the trunk route. Good luck!
Did they do the recall? If they did this seems fishy. There would have been signs of it when they did it and they should have said something. Do you have a different drive shaft or ever did anything with your tank? If it really wasn't their fault a CTS tank should work fine just swap out the module.
They did the recall. It was leaking before they completed the recall and I was hoping the leak was caused by the recall. Still has the stock driveshaft in the car. They have not even put the tank back in because they are trying to find a "cheaper" option for me lol
The tank was already leaking before it went in for the recall so it couldn't of been caused by them. Would a bad carrier bearing cause the driveshaft to move enough?
Only thing I can think off is your diff bushing was shot and the driveshaft was moving up and down a lot with the diff
