View Poll Results: What would you do?
Install the iron LQ4 6.0 as is
1
5.00%
Build the 6.0
6
30.00%
Pull the LS6 and build it to avoid the weight penalty
11
55.00%
Part everything out and return to stock to sell
2
10.00%
Voters: 20. You may not vote on this poll
Decisions...Motor finally went
Looks as if ring land #7 finally let go. I've been going round and round with an internal engine tick for sometime now and figured it'd show itself eventually. Well, that day has come and I'm now at the point of trying to decide how far I want to go with this.
I have an iron 6.0 block that I could throw in as is, or bore and forge it first.
I could throw the 6.0 in for the time being while I stroke the existing LS6 to avoid the iron weight penalty.
Or, I could part the thing out entirely and move on to another project.
What does the community think?
Part out! Deal on and E-force already adjusted for the V1....???!!! Yeah, I want that.
How is building the 6.0 any faster than stroking the ls6?
My vote is stay alum unless the plan is for over 800whp. Which, I would
Enjoy seeing the limitations of that E-force
Edit:but also if you're stroking the ls6 you might as well go 402 instead and alum. Since the only piece you lack is the block. All else is the same. So it's not like it adds much costs, but the benefits would be awesome. So that's my vote.
DMM! Sorry to hear that, man. Let me know when you're going to work on that beast, if you need any help, I'm 10 minutes up the road and want to learn more myself.
I voted build the LS6, only because I'm going to end up probably doing that myself, to go forged and see how much oomph the 112hh has.
RUssell
RUssell
need more info...
Whats you cash flow? Can you afford to just build the LS6 outright without it taking a year? If so do that...
If you're money isn't that strong, go ahead and buy the heads you need for the ls6, slap them on the LQ4 and run it until the bottom end starts to go because it really isn't worth much anyway.
What other projects do you have in mind? If you really want a vette or a classic, part this one down and go from there because this car will never be one of those. If you really think you want a V2, I'd keep going with what I've got because with the list of mods you've got, would a V2 be that much better? Not in my mind....
Good Luck!
Good Luck!
Put forged pistons/rods in LS6, with ported 317s...maybe decrease compression, increase boost. Stock cubes. Water/meth injection, nitrous for more power.
Current setup sounds pretty sick already. Save the LQ4 for something else, because going L92 from where you are now would be...undoing a lot of badassery.
Voted ls6, but not for the weight penalty.
Originally Posted by Sssnake
Forge the bottom, install piston squirters (if your block supports it), swap to an e38 controller and call it a day
If it works i know i will be better off vs the old pcm. Better abs control, better timing, better pe but the same maf readout...
Thanks, guys. Cost is not the limiting factor at this point; time is. I've been going over this and still haven't made up my mind. It helped that I drove my fathers '13 CTS on a decent trip and I just don't like the interior, driving position, etc. Granted, it's not a V2, but I think I'm pretty sure I don't want one.
The LQ4 is from a 2000 Silverado, which means I'd have to swap cranks as the early LQ4 had a .500" longer crank as they were only installed with the 4L80e. The early blocks also had core shift issues, but 0.30" over shouldn't be a problem even if there is core shift.
I'm in Bangkok for another month so I have plenty of time to figure out that I want to do.
Does anyone have any local (MD) recommendations for a machine shop?
From pcm to e38? I am tryin to go with a e67 which came stock on the 06, and there is work to be done. I am hoping to be finished with the engine reassembly this week and install in the car. I will later route the new drysump hoses and turn the key to see if it all works...
I have been looking at your thread and anxiously awaiting your results as I have considered trying an OS change to overcome some of these issues. Specifically if I went to the V2 OS it would give me support for IAT2 measurements. I am actually measuring IAT2 now but feeding it to the computer as IAT1. While not causing horrible problems you do end up with minor issues with this approach (primarily associated with a split between the MAF sensor and the IAT sensor locations).
These comments are based upon my experience with the LS2 CTS V OS. The earlier LS6 based cars may be different.
