Instrument Cluster replacement/repair
So my left LCD screen went out on my cluster, or fades out. You can still kind of see the information, on a hot Texas day it works like normal until the cab cools off and it slowly fades back out. Took it to a dealership and they couldn't get a read on the cluster through the tech 2. Is it because I have a aftermarket head unit? I also have my on star disconnected too. The technician couldn't answer my questions, showed some frustration at me. Also, I called a few local repair shops, one seems confident that they can fix the screen, would you guys recommend it or play it safe with a frustrated tech =D
I would assume that the VIN would have to be programmed by a dealer as is almost everything in these cars. The communication piece could be a bad cluster as well. If you decide to go the route of swapping it out let me know. Hope you get it figured out.
Really iffy subject with which to choose.
First off, I would not do any business with anyone that showed me any frustration for a problem I was having. It's my problem not yours, get over it.
But I would prefer to have a different dealership look at it, unless of course that shop that is confident they can fix it has already had an issue like yours and resolved it.
Best of luck!
Best of luck!
