Canadian Members We never leave because we have The Beer Store
1000hp combo parting out...
Old 06-22-2008, 09:48 PM
Schurters LT1's Avatar
Default 1000hp combo parting out...
Hey Guys,
Well i am selling off everything, i have all the right parts here to make a 600-1000hp car all hi-end parts SO PLEASE NO LOW BALLERS
This is off my 95 T/A
Vortech Ysi Z8's brackets
cog pulleys
8 rib pulleys
FMIC and all the piping with extra clamps and hose
vortech mondo BOV
$4000.00
Alky control
singal/dual kit with an extra pump $550
BBK 58mm TB $200
Vic Jr intake with fuel rails $450
Nitrous Outlet elbow $300
https://ls1tech.com/forums/showth...=782110&page=3
matching AFR heads
These are Z8's old AFR heads that were ported by GTP and mating Vic intake you will not find another set of heads like this with shaft mounts 1.7r $3500.00
84lbs inj $400
Lonnie's twin intake fuel pump set up with Racetronic wiring kit $700
upper/lower A arms BMR/Sphon $600
K-Frame $250
Qa1 shacks with front springs front & rear $650
adj rear control arms $100
BH short block 355.....
eagle rods 4340
eagle 4340
Je blower pistions
4 bolt mail
balanced
ATi extra keyed crank $3000
Morrel's $400
custom Bret B blower cam $300
Accel Dfi with fast track wiring, WBO2 with extra pcm , dual synic dizzy $1200
MORE TO COME
IF DOING PAYPAL ADD 3%
Old 06-22-2008, 11:47 PM
LETZRIDE's Avatar
got any subframe connectors?
Old 06-23-2008, 06:08 AM
yep weld in sphon and they are light CM not steel
Old 06-23-2008, 06:45 PM
hashtagBMW
Speed Density's Avatar
Is the Vic JR ready for the LT1 heads?
Old 06-23-2008, 06:49 PM
the Vic Jr is for the AFR heads i have the heads have been weld and re-drilled for the intake so i want to sell everything together..
jeremy
Old 06-23-2008, 08:35 PM
hashtagBMW
So the AFR's are drilled for an SBC intake, not the other way around. Make sure people know that.
Good Luck though!
Old 06-23-2008, 08:37 PM
thanks,
i will sell it as a top end package, cant brake this up they are a perfect match..
Old 06-25-2008, 11:43 AM
Hybrid36's Avatar
Default K member
I'm assuming the K member is tubular?
what brand?
new or used?
Darrin
Old 06-25-2008, 02:01 PM
what brand?
new or used?
Darrin
PK
yes used
yes tubular
Old 06-25-2008, 05:33 PM
jrcc2002's Avatar
Default cogs
Hello would you be willing to sell the cog drive pulleys and the bov seperate? If so how much you want? If not thats ok. but could you tell me how many teeth each pulley had and how much boost you could make with it? thanks
Old 06-25-2008, 08:40 PM
i might sell them sep....i would like not to break it up at this point
thanks
Quick Reply: 1000hp combo parting out...
