Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Carb'd LS1 for my 71 Camaro
Old 08-20-2011, 10:58 PM
Bparrishlvx's Avatar
Default Carb'd LS1 for my 71 Camaro
Current pics of my LS1 build. Working on the plumbing for the head steam ports and water pump to heater core. Also got the front accessory drive kit installed and turned pretty nice. Need to figure out the hydraulic clutch setup with the tremec 5 speed and spec 3+ clutch next.
Old 08-21-2011, 06:59 AM
In-Zane Moderator
ZONES89RS's Avatar
Interesting cooling setup you got there.
Old 08-21-2011, 02:03 PM
It will be plumbed into the suction side of the wp
Old 08-21-2011, 04:48 PM
Old School Heavy
speedtigger's Avatar
Pretty sexy set up.
Old 08-22-2011, 03:14 PM
Chevy Blood's Avatar
good luck bro
Old 08-25-2011, 05:40 PM
vandal699's Avatar
More info on source and maybe price of the trick stuff?
Old 08-27-2011, 09:51 PM
Made a little progress on the motor today. Recieved the holley 850dp and MSD digital e-curve but need to replace the cast iron dizzy gear for a bronze with the roller stick. Plumbing is slowing as it is extremly expensive for the XRP fittings and line. Have almost $200 in steam lines and fittings alone. It is crazy how much all these little pieces add up to. The autometer adapters for the water temp and oil pressure were $24...for two brass fittings. I guess when you wanna play you better be ready to pay!!!
Started to look at the hydraulic clutch setup I purchased to understand if all the components are going to work with each other...spec3+ clutch, tremec TKO, Keisler Bellhousing, hydraulic throughout, etc. I think they will but have to get the motor off the stand and start mounting items together. Also need to re-wire firewall now due to dizzy location on front of motor and location of water temp gauge...had all wiring setup for sbc.
A couple pics of the porting work on the heads:
Old 08-27-2011, 09:59 PM
Can you guys please tell me what the total advance these carb'd motors like to run at. I am looking at dialing in my advance curves and would some input. Also, since the dizzy has built in rev limiter what max rpm is everyone sitting at?
Motor is 11:1 with trick flow ported/polished heads with 2.05/1.60 59cc chambers, gmpp intake, ms4 camshaft, probe forged pistons, stock crank and rods, arp rod and head bolts.
Old 08-27-2011, 10:22 PM
Old School Heavy
A little light reading:
https://ls1tech.com/forums/carburete...iming-set.html
Old 08-27-2011, 11:00 PM
Originally Posted by speedtigger
Good info read all 4 pages. Thanks!
I will start at
0-300 rpm - 12 degrees
300 - 1000 rpm - 24 degrees
1000 - 2000 rpm ramping up to 28 degrees
2000-on 35 degrees
Old 08-28-2011, 07:31 AM
Old School Heavy
I will start at
2000-on 35 degrees
Make sure you share your results after you run it on that page and the carb'd data base page.
Old 10-15-2011, 11:15 PM
Made some progress today putting the motor in the car along with the tranny. Struggled with the motor mounts not sitting low enough on the saddle to get the bolts through. After six hours in 90 degree heat it's in bit now the crossmember mount of too far back for 1 1/2".
Old 01-08-2012, 08:35 PM
67SS&99SS's Avatar
very clean. where did you get your accessory drive kit from?
Old 01-09-2012, 02:13 AM
1badeagle's Avatar
Any reason you went with the distributor setup? Any advantages?
Old 01-09-2012, 08:24 AM
domchevelle's Avatar
Very nice !!!
Old 01-09-2012, 11:04 AM
WannaBeFast's Avatar
Beautiful car!!!
Old 01-25-2012, 12:38 AM
OUTLAW 7's Avatar
I second the question Bout the distributor... Any advantages over individual coils?
Old 01-25-2012, 07:57 AM
The stunningman's Avatar
[/IMG]
Why you need a bronze gear for the distributor as the new distributor drive is NOT a part of the roller cam. Is the add on cam drive made of the same billet as a roller cam? If I did not need a bronze gear I would not be using it if I were you.
Old 01-25-2012, 11:04 AM
3pedals's Avatar
I will start at
2000-on 35 degrees
Be carefully with timing at the start of your tuning.
Your engine is 11:1, so I would limit total timing to 30-32 to start with, untill you find what it wants
Old 01-25-2012, 11:52 AM
xpndbl3's Avatar
Still not sure how he is going to use the MSD software timing curve on a distributor.
You're more looking at limiting the curve total advance to 18 degrees or so and having 12 initial and 30 total to start out. There is no rpm vs timing "setting" like the new 6010 boxes are. You're doing it old school with a distributor and weights/springs to set the curve.
Quick Reply: Carb'd LS1 for my 71 Camaro
