couple of ?'s: what programmer, what cfm carb
Ok, getting close to that time, so i have some questions for you guys. So ill tell you the setup.
LS2 block, 6.0 crank(truck crank b/c the LS2 one was no good), LS3 rods with ARP rod bolts, Mahle pistons with valve reliefs made bigger for LS3 valve, LG G6X3 cam on a 109lsa, stock LS3 heads, and Edelbrock L92 carb intake manifold.
So i ask you, what size carb do i think i will need, and what controller to go with? Go for the MSD? Or the one GM makes?
Carb size depends on a lot of factors. What is the estimated weight of the vehicle? What transmission and rear gear? If its an auto, what converter? And what will the vehicle be used primarilly for? Or you just call up Pro Systems and tell them your specs and let them build you a carb. Eric L
The GM ignition box sure looks like the MSD unit repackaged with their label. MSD makes the one for Edlebrock too.
Probably 99% of the guys on here run the MSD unit, so you will get biased answers. Unless you are doing something way out of the ordinary it is hard to go wrong with that box.
The standard answer on carbs is to "call pro systems". However there is at least one respected member on here who bought a pro systems and now is telling people to get a quick fuel. Pro systems has some nice stuff and lots of guys have good luck with them, but sometimes it isn't as easy as one phone call.
i thought of it, but after talking to the guys at LG for a couple of days, we chose to go with there g6x3 cam on a 109. several reasons for this and i want to see what is does since it makes good numbers.
thanks for the input guys
