Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
My LM7 build into a 1994 Silverado
Old 05-10-2012, 03:38 PM
RabidStreetRacer's Avatar
Default My LM7 build into a 1994 Silverado
1994 Silverado stepside currently with a 350 TIB and 4L60E
My soon to be Sleeper
Engine and trans parts that are going in:
862 heads milled 0.015, 45 degree cut valves and with LS6 springs
Edelbrock Performer RPM Carb'd LS1 Intake manifold
Holley 750cfm double pumper carb
Holley Fuel pressure regulator
K&N Xstream 14" air cleaner
Comp cams Thumpr Cam
MSD 6LS ignition
Dirty Dingo engine mounts
LT Headers 2" primary's
(2) SLP Loudmouth mufflers
GM flywheel adapter with longer bolts to use my early 4L60E, thats right a carb with a 4L60E.
Transgo HD2 Shift Kit and Corvette servo
I have had a lot of work set out for me to clean this engine, here are the pics.
Old 05-10-2012, 03:39 PM
Old 05-10-2012, 03:40 PM
Found a hole in the timing cover, source of most of the oil on the engine
Old 05-10-2012, 03:41 PM
Broken harmonic damper
Old 05-10-2012, 03:42 PM
As it lays now
I will probably finish the painting next week and start putting it together
Old 05-10-2012, 04:45 PM
In-Zane Moderator
ZONES89RS's Avatar
Carb and 4L60? Never heard of it:
That controller was 550$ or so.
what headers? I used the Schoenfeld 1 3/4 3 inch collectors, where are you getting 2 inch primaries?
Old 05-10-2012, 06:17 PM
I am going to hook up the stock TPS to my carb and allow my existing computer control the trans.
I bought the headers from someone on another forum. He said they are a custom set from Schoenfeld and are made to be able to reach the rear spark plugs.
Old 05-10-2012, 08:15 PM
In-Zane Moderator
ZONES89RS's Avatar
I am using a earlier TPS, the 86-91, works great, and the hand held tunes everything, also allow lock up and performance shifting at the flick of a button/switch if you like. Dont think the older 4L60 that was in it would have lived behind this motor, yours probably wont live behind the larger engine you have with a cam.
Do your headers look like mine?:
Old 05-10-2012, 08:43 PM
These are the ones I got:
Old 05-10-2012, 08:46 PM
I am putting in a HD2 shift kit and a corvette servo to help the trans for about a year untill I can pick up a T-56 to swap in.
Old 05-11-2012, 08:04 AM
Andy's Auto's Avatar
Awesome build you have going on there. My first attempt at LS swaps was a 6.0 earlier this year that I ripped out of an 03 3500 Express. Poerted 862s and a .629 lift Comp cam got me an 11.34 first pass in a 78 Malibu. Lot lighter than your truck but something tells me speed will come.
Old 05-11-2012, 08:16 AM
In-Zane Moderator
ZONES89RS's Avatar
Well, keep us updated on that Trans, I think it will die fairly quickly if you drive like me.
What MPH? Did a 6.0 in a Malibu with heads I touched up, only flowed 270ish, stock 317s, did 7.3 with 3.42 gears. Think it hit 96 mph? Had the torqer v2 cam, th350 with a 3500 converter.
Old 05-11-2012, 04:12 PM
Very nice track time. I would be happy with a low 13 second pass.
Old 05-11-2012, 08:12 PM
GNCLONE's Avatar
Cool build!
I took that long filler neck off my valve cover and the cap fits right on there.
Old 05-11-2012, 08:48 PM
In-Zane Moderator
ZONES89RS's Avatar
Ancient Chinese secret
Old 05-12-2012, 08:59 AM
Originally Posted by GNCLONE
Cool build!
How the heck did you get it off? Mine feels like it is glued on there and is going to break when I try to twist it with pliers.
Old 05-12-2012, 09:02 AM
89sierra's Avatar
i dont know if you are going to do the tranny or you know someone that does but i would suggest giving the tranny a once over before you put it in and i would also upgrade to a beast sunshell
Old 05-12-2012, 11:37 AM
Got a local shop here who said they would do a look over and install the HD2 shift kit, corvette serve and a filter for around $200. I will look into the sunshell, thanks for the advice.
Old 05-14-2012, 06:42 PM
Painted the other side of the block today. I will probably paint the timing cover I just got in the mail and some other misc pieces in the next few days. I will probably install the cam and put the heads on within the next week.
Quick Reply: My LM7 build into a 1994 Silverado
