l4q carb conversion setup suggestions
ok guys i wiped the 454 in my chevelle and was looking at replacing it but hell for the cost of another 454 id rather have a 6.0 that is more reliable and probably gets better then 9mpg. my question is what setup do you suggest i wanna stick with 317 heads and id like to have good power but also want it cruise friendly and reliable. i alreadyhave a 750 dp carb th400 with 3k stall and 3.73s , so my questions are
.what cam?
.what intake?
.what ignition?
.anything else to be aware of?
.what cam?
.what intake?
.what ignition?
Best bang for the buck is getting 6.0L out of a truck and putting the carb on that. The advantage of going carb is you don't need to worry about truck intakes clearing your hood.
If you want to save some weight than you will pay a bit more to pick up a motor with an aluminum block. This still might be the cheaper option overall if you need to buy different accessories/oil pan to fit your car or want to ditch the truck cam.
If you get something with VVT then you will need to replace some stuff to delete that.
For ignitions your only real option is the MSD unit. Don't get the Edlebrock box. It is made by MSD but they deleted the lap top hook up so it isn't as tunable as the MSD one.
As for intake and cam you are going to need to figure out what you want in a bit more detail. I run a stock cam LS2 (243 heads) with a single plane intake and 750 double pumper. I have been so happy with the way it runs I haven't felt the need to upgrade. Phenomenal street manners and being rated at 440 HP it has more than enough grunt for my 2500# car. I have the tickets to prove it. Truck motors have valve springs and cams that float and run out of breath at upper RPM's. Switching to even an LS6 style cam and valve springs will free up a lot of high end HP.
Carbs intakes can pick up almost 30 HP compared to EFI. I don't like dual planes on an LS motor but admittedly they are a popular option around here. The GM single plane has the lowest hood profile, the Vic Jr is a bit taller and I believe the dual planes are taller yet.
As for gas mileage the LS will be massively better than the big block, but switching to an overdrive trans will get you into the mid to high 20's. I understand wanting to save some money and reuse a trans, but if you shop around you can probably get a deal that practically gives you the OD auto for next to nothing. You will need some type of controller if you do go that route.
In-Zane Moderator
I cannot add much to pop n wood's suggestions besides calling Martin at tick performance once you have your engine lined out. He can grind a stick that best suites your needs for the cubes and car with your intended use.
I abandon my bbc project for the LS. Just too cheap and cost effective. Maybe I'll try a big block when I'm not on such a tight budget.
thanks! you guys are great BIGHAL I will be contacting you soon, I just paid for my motor tonight it will be ready to pickup from my local salvage yard on Saturday, I paid 1300 for an 06 lq4 with all the accessories and I got to hear it run before hand and let it get to operating temperature and checked the oil . couple more questions..
why no dual planes for the ls pop n wood ? I always thought they were more street friendly? no?
how does yours sound with the stock cam? have a good grunt?
basically is there a specific reason yall went with a carb? like I said its gotta be able to start up and drive without being a bear
I think if your going to stick with the 3.73 gears go with the dual plane intake its rpm performer.... with a stock cam it will idol smooth at 700 rpms,,, I have a stock lq4 motor in my mustang time in the sig,,,,
In-Zane Moderator
If you dont know anything about carbs and do not learn easy, then EFI and Carbs will be more along the line of a buddy helping you, so either way it is worth it. The carbs are super simple. EFI, not so much. The carb is plug and play and for the EFI to catch up with all the abilities our 300$ ignition controllers have, its even more money.
LS motors are pretty street friendly already. They offer more HP and torque than first gens. But mainly because with roller everything in the valve trains and vastly improved head designs I think of LS motors more like a Brodix head roller cam'd small block that is made to rev. Just seems a shame to not take advantage of that top end. In my case my car is so light I simply don't have enough tire to use all that low end anyway, so might as well trade some of it for high end.
Plus the difference between dual and single plane is about the same as one step difference in cam size. Not everyone will agree with that but I seems to me the intake and cam selection need to be made with each other in mind.
By the way, wideband 02 sensors allow dialing in a carb in way that wasn't possible back in the muscle car days. Carb motors don't have to be hard to start.
well guys I pick my motor up and ive been tossing around the idea of a turbo setup on factory injection or throwin heads and a cam and having it tuned by an efi tuner but honestly im right back here to the carb section....lol what kinda power do you think this thing can make with a single plane intake and a 750 quick fuel that I already own? plus a cam, id like to stay with stock heads to keep costs down. with the lower compression of 9.4 will it still sound mean with a cam and headers because that's what im after
I have a 94 S-10 lq4 Victor Jr 850Barry grant carb 317 heads milled 20 homemade headers 595 605 comp cam edelbrock ignition and the ignition is all I'm going to change love the way it runs 7.35@94 in the eight out run lots of built stuff hope this helps u know what to expect and I would go msd ignition if it were me it's cheaper to buy box and intake seperatly not edelbrock combo I know from experience
keep the 317's, just mill them for compression.
a .050" cut with a stock replacement gasket will get you close to 10.75 to 11:1
FYI it will pull a 12 sec pass without changing anything, when i first ran my 6.0 in completely stock form, but with the vic jr, 850 carb, and headers, it went 12.59 @ 109
Thanks for the input 3 pedals, so do you think my quick fuel 750 carb is not enough for her? Also won't that be a bit to much compression for street manners? Also what about ptv clearance and pushrod length?
Your 750 will be perfect.
Ptc clearence will be fine on stock cam, if you want a bigger 1 then you may need to flycut the pistons while you have the heads off. Pushrod length will depend on everything, best to measure and get the right length.
10.75 to 11:1 will be good on 93 if you have a fairly good size cam.
Basically you should decide on what limits you are imposing on the build such as drive ability requirements, power/et goals, etc , and plan the compression/cam and all the details for the whole combo before you even turn a wrench. That way if intend to build in stages, you won't need to do stuff twice
