LQ9 in 01 Camaro
LQ9 in 01 Camaro
Hi, i have a 2001 camaro z28 that i recently put a lq9 408 stroker in, i got the short block from texas speed and performance and the heads and cam i got from them too, its been in the car for about 9 months and im not happy with the fuel injection and want to put a carb on it but i do not know what steps to take. obviously a different intake, fuel regulator, but i dont know what to do about a distributor (if i even need one), ignition box, and how to make it so all my stock guages still work and because i live in delaware i need it to pass inspection ( which is basically they plug in and if there are no codes im good to go) also since i have a 4l60e what do i do about that. Has anyone gone through this before?
In-Zane Moderator
There is a sticky above:
https://ls1tech.com/forums/carburete...need-know.html
Lots of info you need to start soaking up, most of what you want is answered and you will be able to go forth with a ton of confidence in the conversion to carb.
Pics of said car or it didn't happen. Lol
about 550 at the wheels with a 4k stall, and i believe 46lbs injectors
