dyno tuned
dyno tuned
Well did a little dyno tuning. After spending several hours chasing my AFR gauge around and around. I decided to take it to the dyno. I'm glade I did. It is not working right and its brand new. but anyways I have a
2001 5.3L
750 proform
edelbrock single plane
MSD ignition
custom headers
Trick flow cam
299 rw hp @ 5800 rpm
292 rw tq. @ 5300 rpm
2001 5.3L
750 proform
MSD ignition
custom headers
Trick flow cam
I have an almost identical build to the OP, except his has a cam and mine is still stock.
How far off would my numbers be compared to his? I have a nitrous converter that according to Freakshow Performance should footbrake to around 2800, and nitrous flash to 4000, and still on 3.08 gears (yes I know they will be killing my times). And no springs on mine either.
Man , they must have something special going on in the air down under, OR you where guestimating 1/8 mile ETs ? The air around where I live will give a solid mid/high 12 with less than 300 rwhp.
Nothing wrong with down low with a stalled auto either, IMO. I really enjoy lugging through 1st and 2nd at mid throttle. The speed limit comes up really quick and gives a nice shove into the seat. Almost feels like playing with a clutch trans! A cam setup for good average power and a 2500-2800 stall makes for a fun ride!
For comparison, here is my dyno graph. Albeit almost pointless to compare 2 different dynos…
-2001 5.3 with 106K when installed, now 109K’ish
-Completely stock internals
-Used/rebuild Speed Demon 750
-Edelbrock dual plane
-Ebay 4th gen SS headers, 1 ¾” Primary, 3” collectors
-3” straight pipes to Thrust mufflers dumped at the axle
-Rebuilt TH350
-2000RPM converter
-Original 2.73 gears
I think I am running into some sort of a top end issue as hp&tq peaks are to early and start to fall off too soon. I just got an AFR gauge installed and I am starting to put it to good use. I will also be swapping out the OEM springs for some Comp918s in the next couple weeks.
Do you have a graph or vid? Did you ever get your carb issues sorted out?
-Rebuilt TH350
-2000RPM converter
Old School Heavy
-Rebuilt TH350
-2000RPM converter
[/URL]
-Rebuilt TH350
-2000RPM converter
[/URL]
