fuel pump and regulator?
So I am building a 408ci engine with an s480 turbo and shooting for 700+hp I just had a few questions about the fuel pump and regulator I have a 255 in tank pump right now and was just wondering if that would get me started or if I should go with something bigger and with the regulator do I want one with a boost reference?
Thanks for the help
Jesse
Thanks for the help
Jesse
Ok I haven't really looked to far in to it yet but I've heard that if your going to use the a 1000 for the street you need to have a pulse with modulator or something for it so it doesn't burn up?
Too big of a pump is just a noisy pain in the ***. Why not upgrade to an Aeromotive A340 pump? Should fit where your 225 lph pump sits and Aeromotive claims they are good to 900 HP on a forced induction carb motor. Half the price of the A1000 plus whatever you save by not having to buy new fittings.
You might look at the flow curve for your 225 lph pump. That is the flow rating at EFI pressures. At carb pressures it will flow quite a bit more.
Most return style carb regulator will work with boost, like a Mallory 4309
That was my original thought I was going to go with a 340 but thought it was best to check with you guys who have done this before eventually I would like to brake in the the 1000hp mark so if I go with the 340 or just keep my 255 and see how it works and I need more would it be ok to just put the a1000 in line and and leave the other pump in the tank ?
Im getting ready to start purchasing parts I was looking at the Bosch 044 inline and the Mallory 4309 regulator. Just trying to keep the cost down if I outgrow it I will worry about it then.
The OP needs a big pump because of his HP goals. 700 HP is nothing to fool around with, you need to put some effort into getting the fuel system right.
