Whats a good cam for low end power and tq
I have a stock lq9 with a dual plane intake and a 750hp carb. I am looking for a cam that's going to make good hp and tq without having to spin the motor to 6500rpm. The Trans is a 700r4 with 3200 stall and the rear has 373 gears. Thanks
Old School Heavy
When I first built my car, I had an LQ9 with a dual plane Edelbrock Performer and a 2800-3000 stall with 3.90 gears. The cam I started with was the Comp Cams XR275hr12 (222/224 .566"/.568" on 112+3). That setup had power everywhere. In fact, first trip to the drag a trip that combo pushed my #3780 car to an 11.76 @ 113 with a 1.65 60' time on the first pass hot off of the street.
With your 3200 converter you can probably run any of the popular 220 or 224 cams with a 112 LSA or tighter. Also, that dual plane will like an ICL in the 106 to 109 area with a 220s duration cam. Lots of choices for want you want to do.
Old School Heavy
That cam is into the 230+ duration @ .050", so it is on the large side for somebody with a street car who specified an emphasis on torque. If you want more of a hotrod type idle I would pick this cam for what you are doing over the Torquer V2:
http://www.tickperformance.com/tick-...1-ls6-engines/
I have a very similar cam in my car now and it is very strong and sounds good. For that cam, tick offers milder or more aggressive lobes, if it were me, I would pick the milder lobes. They are just a better choice for the average street car in my opinion.
It's a 91 s10 short bed ext.cab that has a stock lq9 motor with a dual plane intake and a 750hp. The headers are 1-5/8 mid length with 3 inch exhaust. The Trans is a 700r4 with a 3200 stall. The rear has 373 gears with a 26 inch tall tire. The truck weight is 3250. The motor is bone stock with stock 317 heads.
