Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Cylinder head steam pipes
Old 01-06-2015, 06:12 AM
VLS1's Avatar
Default Cylinder head steam pipes
Guys I am wondering how everyone is running these on their carb setups? Just vented at the front and blocked at rear, or running all four to one pipe etc.
TIA
Old 01-06-2015, 07:51 AM
tim burks's Avatar
im using the factory crossover and my radiator has a place for the vent line
Old 01-06-2015, 07:54 AM
TXsilverado's Avatar
I have all 4 connected and running to a jtr steam vent in the radiator hose
Old 01-06-2015, 07:56 AM
Like this but it now has the early camaro crossover that connects all 4 vents.
Old 01-06-2015, 11:54 AM
Horsepwraddict's Avatar
I run the back two blocked off and I welded a nipple to the outlet on the water pump for the front. Im using the stock front crossover.
Old 01-06-2015, 07:01 PM
Doug G's Avatar
I'm running the TrickFlow 4-corner kit....but you could do the same with a tap, some AN fittings, and a few feet of braided line.
Oh, and I tee'd into the thermostat housing.
Old 01-07-2015, 07:16 AM
homemade87's Avatar
Here's what I did to mine . The water passing the fitting is going straight into the hose anyway . I did not see much need to do more . Has worked flawless .
Old 01-07-2015, 08:18 PM
Pop N Wood's Avatar
Funny, I did mine just like homemade87. I have an LS2 with only the front two plumbed and the back two blocked off.
Old 01-07-2015, 09:12 PM
lblevins's Avatar
my ls3 heads have the rears plugged from the factory and I have the front 2 plugged same way I had my 243 heads. All plugged and never had a problem.
Old 01-08-2015, 08:48 AM
homemade87's Avatar
I would suggest plumbing the front in . Generally you can get by without the rears because the head rises in the front and the steam/air will move to the front of the head at the highest point . These engines are designed this way can not purge the air on there own . Think of it this way . If you hold a bucket upside down under water where can the air go unless you remove it some way . Thats what the steam lines do .
Chances are you have some hot spots in the head and could cause detonation and damage and you do not even realize it until its to late.
Old 01-08-2015, 10:37 AM
lblevins's Avatar
Well I guess I can throw it on for good measure. My last engine made it thru almost 30k miles and lots of road trips and probably 100 1/4 mile passes. I sold it to my buddy and it's been in his truck ever since. Guess I get really lucky.
Old 01-08-2015, 09:37 PM
VLS1's Avatar
Great info thanks all. I was planning on only using front vent pipe, and jacking front end when filling/bleeding cooling system which may also help matters.
Old 01-09-2015, 07:10 PM
sbmalibu's Avatar
Has anyone ever tried to pull out the plugs in the back of the newer heads?
Old 01-10-2015, 03:42 PM
3pedals's Avatar
yes, just use a drift and knock em out.
Old 01-10-2015, 04:05 PM
WEIGHTMAN's Avatar
off hand what size an would fit
Old 01-10-2015, 06:35 PM
Doug G's Avatar
You would need to tap it 1/8" NPT and then get the pipe to AN fittings. Most likely need to drill first, then tap.
-2 or -4 should work fine.
Old 01-11-2015, 10:32 AM
Pop N Wood's Avatar
The rear plugs bolt in just like the front ones. That is how you get plugs to block off the front vents, they first introduced them with the LS6
The vents aren't absolutely needed, lots of guys block all 4 vents. You just need to make sure you purge all the air every time you fill the coolant system. Steam vents are a misnomer, they are there to vent the air on the initial fill. If there is any steam in the head then you have other issues. Lots of opinion on this topic. Some guys swear not venting all 4 corners means it is only a matter of time before you smoke a head.
Old 01-12-2015, 01:56 PM
WE TODD DID's Avatar
Made something up here
Old 01-12-2015, 02:49 PM
Doug G's Avatar
Looks good....better than the Trickflow one
Old 01-12-2015, 07:22 PM
WEIGHTMAN's Avatar
so couldnt you just put some bleeders on the front then
Quick Reply: Cylinder head steam pipes
