Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Anyone tried a carb intake and dist on a ls1?
Old 09-22-2010, 07:18 AM
  #221
In-Zane Moderator
ZONES89RS's Avatar
Moving this to the new location.
-Z
Old 10-26-2010, 02:30 PM
  #222
marco_chevy's Avatar
Default Carburetor problem
The season here is finished, or very close to be. After 1 summer whit a carburated LSx, i can tell that i'm very happy whit this new set-up in my 69 camaro. L92 6.0L, Msd 6012, GM intake, good comp cam, Map sensor and all other stuff run very well..
But, I have 1 problem, my carburetor did not work good.. --- I have started a new post for this problem.
Thanks.
Old 02-06-2011, 01:32 AM
  #223
pontiac 2+2's Avatar
Originally Posted by Rodder
You're better off with the MSD 6010. The Edelbrock can't be programmed with a laptop, and all of the Edelbrock pre-programmed curves have too much total advance.
I have the Edelbrock control and I can custom program it. If you look, you will find that MSD makes the CU for Edelbrock.
Old 05-20-2011, 12:57 PM
  #224
mm8ls1's Avatar
Default LS1 Dist & Carb Swap
After reading this post it wasn't clear if anyone had actually swapped their LS1 to a carb and distributor. This was seen on HP TV a couple of years ago. I'm only looking for responses from those who have done the actual FULL swap that includes changing over to a distributor.
I see that many have left the coil packs on and install an MSD box, but I'm not interested in the coil packs whatsoever.
I hate the look of a cluttered engine bay with wiring harnesses, pulleys etc...
Old 07-28-2011, 09:46 AM
  #225
MASS seller approved
Johnmaster's Avatar
Doubt you'll find too many who have. Hard to give up programmable timing and electronic reliablity while having to completely retrofit a special distributor onto it. If a clean look is what you are after consider routing the unit and the coils through behind the firewall too. Can't think of a cleaner look than having 8 wires appear from nowhere and discretely attach to the plugs. They also make fake valve covers that cover the coils. Pricey though.
What am I missing here?
Edelbrock 7118 kit is $670.
Manifold is only 266 by itself.
MSD 6010 is programmable and is 319 by itself.
Edelbrock unit (made by MSD) is not programmable, just rpm modules?
Save $86 and get programmability by buying separately?
The photo showed a large style GM MAP sensor, does that come in the kit? Still not worth $86 to me.
Old 08-20-2011, 11:24 PM
  #226
Bparrishlvx's Avatar
Default Carb'd and Distributor for LS1 Pics
Here is mine in it's current state. MSD Digital e-curve on the way.
Old 01-03-2012, 12:35 PM
  #227
LSxChevelle's Avatar
Horsepower TV will have a 1st Gen Camaro on the show soon with a carb/dist 408.
Old 07-17-2012, 02:35 PM
  #228
NEXRACE's Avatar
I have a stroker v-6 that was set up for off road. I had the carb shop in ontario, ca do a carb set up. That thing idols so nice & runs smoother that my injected 5.3 lsx I have in my sandrail now! My dad told me, "If you ever have an injection problem with the v-8, you know what to do."
Old 08-14-2012, 05:27 PM
  #229
1994z's Avatar
Default here is my setup in the 65 chevy II
6.0 ls stock bottom end. cam and headers,850 carb. and dist. hopefully will be at holley ls fest.
Attached Thumbnails Anyone tried a carb intake and dist on a ls1?-65-chevy-ii081.jpg   Anyone tried a carb intake and dist on a ls1?-65-chevy-ii080.jpg
Old 10-09-2012, 08:55 AM
  #230
dogsballs's Avatar
anyone got a part number for msd plug leads for dizzy? or people go custom.
Old 10-09-2012, 04:33 PM
  #231
1994z's Avatar
i just bought the msd cut to fit wires. likes whats on mine.
Old 12-04-2012, 06:00 PM
  #232
swift73's Avatar
i have a 6.0 stock bottem end with a cam and ported stock heads im having problems with the motor turning up im thinking my carb is to small and a friend of mine is saying i need to change the gears i need help......... any answers please
Old 03-06-2013, 10:06 PM
  #233
BigEd_72455's Avatar
Originally Posted by Shawn MacAnanny
Where did you get that at Jay? Radioshack or Wal-mart or something?
http://www.ebay.com/itm/3Ft-Transluc...item58924d34de
oops!!! just realized that was a 4 year old posting!!
Sorry!!
Old 04-26-2013, 09:13 PM
  #234
littleredVH's Avatar
Default LS with a distributor
Bparrish, thats a sweet looking motor you have built, i love the detail.
I have gone a different route than everyone else, i am using the Electromotive XDI system with a 2006+ 58 tooth wheel installed into the LS1. I will use the sensor for the Electromotive installed into the factory hole with an adaptor, hence the engine running stand.
I got the efi version of the manifold if i want to use the Electromotive TEC system in the future in another car
Nigel
Attached Thumbnails Anyone tried a carb intake and dist on a ls1?-ls-80-.jpg   Anyone tried a carb intake and dist on a ls1?-ls-89-.jpg
Old 06-23-2013, 07:33 PM
  #235
billymgb1000's Avatar
I have been running edelbrocks carburetor set up it comes with the intake and msd/edelbrock ignition box on my 2001 ls1 I put a 600 cfm carb on it and she runs great I mounted the box to the fire wall so for so good
Attached Thumbnails Anyone tried a carb intake and dist on a ls1?-100_1596.jpg   Anyone tried a carb intake and dist on a ls1?-100_1593.jpg
Old 09-05-2013, 08:57 AM
  #236
dogsballs's Avatar
i run both the dizzy and mech fuel pump
Old 10-18-2013, 11:09 PM
  #237
Wildcobra's Avatar
more good info
Old 11-13-2013, 08:09 AM
  #238
FultonPerformance's Avatar
Would a 6.0 with a good cam and some bigger valves in the heads run good with the edelbrock intake and holley 750? I like the msd setup since I discovered it but I am wondering will it be worth selling my spare 350 4 bolt and parts to go with a junker 6.0 block with a cam. I like the fact aftermarket heads aren't really a big deal with the ls platform but before I go and drop a good chunk into a carb intake and msd box I would like some track proven results. Also how exactly does the 2 step launch work? I have a 3500 stall and never used line lock or trans break or 2 step.
Old 01-22-2014, 02:17 PM
  #239
Heavychevy87's Avatar
I'd go msd 6ls as well
Old 01-22-2014, 02:31 PM
  #240
Summit also make a fairly easy to install efi kit now as well
Quick Reply: Anyone tried a carb intake and dist on a ls1?
