Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Please help! '96 Camaro 383 stroker trouble
Old 03-31-2013, 10:39 PM
NickSweeneyLT1's Avatar
Default Please help! '96 Camaro 383 stroker trouble
So I just bought my first camaro and it was quite the car.... for the first couple days. Now I have a problem that is getting old really fast. First off the car is throwing a P1361 code, the car runs incredibly choppy when accelerating and working through the gears. Although it seems to not be as bad when I grab a higher gear, usually one higher that needed. If you text me I can send you a video of the problem happening 717-3500163 please help me out if you can!!!!
Old 03-31-2013, 11:12 PM
Sweet_SS's Avatar
https://ls1tech.com/forums/lt1-lt4-m...ode-p1361.html
OR
https://ls1tech.com/forums/lt1-lt4-m...293-p1361.html
Old 04-02-2013, 10:04 AM
camaro448hp's Avatar
optispark????
Old 04-02-2013, 09:46 PM
I was told it has an optispark distributor for a 98-02 Camaro, but it has coil packs atop the valve covers... Does that make sense? Here is a list of what was done to it, and conveniently the previous owner is now not answering his phone, what a surprise.
-Budnik cobalt billet wheels 17x9.5 front.
17x11 rear.
-Msd 6a ignition box
-Ltcc coil conversion kit
-Ls1 coil packs
-Cardone optispark distributor 98-02
-front brake conversion Drilled and slotted front and rear rotors
-New front and back brake pads ---After market bigger front and back sway bars
-Weld in sub frame connectors ----Centerforce clutch
-Eibach sport springs
-Revalved bilstein shocks
-Eagle 383 stroker kit
-Lt4 intake
-Ported and polished corvette heads
- 1.6 roller rockers
-Bbk 58mm throttle body
-K&n cold air intake
-Mezire electric water pump
-32# fuel injectors
-New wheel alignment
-Lt4 hot cam
-New 98-02 camaro ss spoiler ----Clear front bumper lights
Quick Reply: Please help! '96 Camaro 383 stroker trouble
