4th gen tow hooks
4th gen tow hooks
I own a '99 Camaro SS, and would like to install tow hooks (track use). I've been through all the threads I can find related to tow hooks, dozens of pages from searching the Internet, but I can't find any useful information on this.
Does anyone know of a tow hooks (front/back) that fit our car? If not, any suggestions on a generic hook and mounting options?
Thanks.
Thanks.
great idea! never thought of that. neither did the ******* whole tied down my 98SS w/ 17,800 miles and ripped out the factory underbody eyelets that are supposed to be used for chassis alignment.
For posterity's sake:
I had this unit welded to the outside of the frame rail on the drivers side.
http://www.rennline.com/Rennline-Uni...oductinfo/E80/
I can provided pics if anyone is interested.
if you have the filler panel in the bumper you can cut out behind it and cut the foam then weld a hook or some bent bar to the impact bar. when you need the hook remove the panel when you dont need it push the panel back on
