wheels.. and tires
wheels.. and tires
So I have a 2002 z28 . I have ss wheels on it.. with nitto extreme 555r tires .. 275 on all four , I wanna do a different look but what these size tires , 275/40/17 for front and 315/35/17 for rear .. I know what brand tires i want just can't seem to find a wheel I like or one that would fit .. my car isn't lowered
ZR1 rims question
I like those rims BTW, but I just bought a 94 Z28 and it came with a set of the same rims. However, I have a 17x 10.5 in the back... what size tire should I run? 305/40r17? I really have no idea... help plz
I need info on what is needed so I don't scrub. Thx, Scott
I had a ws6 lowered on eibach sportlines with a 1.8 drop in front and 1.4 rear, and i ran 315 in the rear on 17x11, it would have rubbed, but only a little bit, so i hammered the piece inside a bit and it worked perfectly, i think stock height you will be just fine.
I also ran 17x9.5 with a 2" spacer in the rear for this look....loved it but those hit the fender, so had it cut...car was a salvage but couldn't tell that's for sure...lol
At stock height I had nitto 555r 305's on a 18x10.5 rim years back. Solo the tires would rub a little on dips or speed bumps and rubbed a lot more with just one passenger depending on how heavy the person was. I never did the BFH mod on the car though
ZR1 17x10.5 rear question
I have a 17x10.5 for the rear rim with M/T drag radials. About to put a 315/35/17 on there. Question is... What do I need to do to accommodate for them? Suspension, spring spacers, ect... I've never went passed a 9.5 wide. Any help is awesome... Thx
275/40/17 front and 315/35/17 rear have the same rolling diameter so mph and odometer mileage will not be affected. I've been running the Nitto 315/35/17 on the standard 17" SS rims (I realize that the 315s' are to be used with wider rims) for 6 years.
Drove down to Florida from Ohio a few times with them on.
275/40/17 Nitto 555 on front,315/35/17 Nitto drag radials on rear.
Strano springs zr1 17x11
Just wondering if anyone has lowered their car on strano springs and put the 17x11 zr1 wheels on the back and what tires? Would the 315s fit or rub? Any info would be great
From my experience as I had 17x11 on stock suspension before, I had to cut and remove my bump stops in order for it not to wipe out my inner tire walls. I also had rubbing issues. This was with the deep dish ZR1 style (not sure if they were OEM or not, just know they were chrome). I was running 315/35R17 Nitto NT555 tires on stock struts and springs with heater hose mod and I rubbed like a bitch.
Picture of my old SS with the wheels.
