Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
is an LS1 an LS1
Old 07-26-2008, 10:42 PM
JP_camaro_68's Avatar
Default is an LS1 an LS1
im looking to get an 04 LS1 gto engine. the queststion is are all LS1 the same because i could also choose an 99 SS LS1. please all input is appreciated
Old 07-26-2008, 11:14 PM
fast01z28's Avatar
the heads, cam and intake manifold changed throughout the years. also the alternator moved based on the car the engine came in.
Old 07-27-2008, 04:04 AM
WANNABE GENIUS
wannabess00's Avatar
I think the GTO has a different intake from the F-bodies
Old 07-27-2008, 07:07 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
All the LS1 cars 01 and up had the LS6 intake. Not sure if the throttle body was drive by wire on the GTOs or not.
Old 07-27-2008, 10:18 AM
BadBandit69's Avatar
01 and newer also got better rod bolts
Old 07-27-2008, 04:41 PM
redbadss's Avatar
im pretty sure the gto motor has more power stock. the gto has a ls6 intake, the 99 SS doesn't. id go with the gto motor, but IMO you can't go wrong with either one(all Ls1's are badass motors).
Old 07-27-2008, 05:06 PM
lemons12's Avatar
as far as speed goes.. yes.. all are going to be with 1 car or so of each other.. no matter what it is in....
as far as where things are and what type of cam intake injector size rods and all that stuff.. no.
Old 09-11-2008, 12:24 PM
tones2SS's Avatar
Thumbs up
I do believe you are correct on the horsepower between a 99 Camaro LS1 and a GTO LS1.
Old 09-11-2008, 01:30 PM
It's not mine! woo hoo!
demonspeed's Avatar
The 99 engine will have the LS1 intake with EGR. I would go with the GTO engine simply for the intake (if have the same miles/price). Everything else is moot.
Old 09-11-2008, 01:40 PM
redracer1's Avatar
Did the '99's have the 241 heads also?
Old 09-11-2008, 02:00 PM
Pretyflywiteguy's Avatar
there's a thread around here somewhere that shows the differences between the years but I can't find it.
Old 09-11-2008, 06:20 PM
Sharpe's Avatar
843, which put out the same power. 01+ had a few more ponies due to the intake, which goes used for about $350.
Old 09-11-2008, 06:28 PM
brandotron's Avatar
Another vote for the GTO motor
Old 09-11-2008, 07:16 PM
Summerwolf's Avatar
Its a cable driven throttle body on the 04 GTO, and it had the best cam of the LS1 motors (not ls6) also the 04 GTO is an LS6 block with an LS6 intake. It would be the better choice of the two as it had all the best attributes of the LS1 motors.
Quick Reply: is an LS1 an LS1
