Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
If it was your car???
Old 09-06-2008, 04:05 PM
JWG01LS1's Avatar
Cool If it was your car???
Plain and Simple,
If my car was your car, mods in sig.
$2000 cash to spend on car
What would you do? No dress up stuff! No Nitrous! but what would your 1st step to making my car a fast street car be?
Driveability and Reliability Matter
Thanks
Jason
Old 09-06-2008, 04:33 PM
73brewstersd's Avatar
4.10 gears, LCA's, Sub Frame connectors, panhard bar, lowering springs, then Bilstein shocks.
Old 09-06-2008, 04:38 PM
TODDS93T/A's Avatar
heads cam and intake and dyno tune you gona do the work your self
Old 09-06-2008, 04:39 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Find a used 12 bolt or 9"
Old 09-06-2008, 10:48 PM
JWG01LS1's Avatar
Dang! all good suggestions... but all different!
Keep em coming guys, i want to get a order out this week
Texas speed or Thunder Racing for sure!
Old 09-07-2008, 12:45 AM
BAD-GTO's Avatar
ported 243's and a cam from TSP
Old 09-07-2008, 12:49 AM
B4CU's Avatar
Fast 90, gears, and get some D.R.s. With a cam you will be changing the valve springs more than once, maybe more depending on how big it is. I don't think that is really "reliable." A 50 shot of nitrous is more "reliable" than a cam and won't hurt your car.
Old 09-07-2008, 08:18 AM
JWG01LS1's Avatar
Hey thanks guys.... theres so many options out there its somtimes hard to know what to do. Im thinking i should save another grand and get 1 of each of the suggestions!!!
Old 09-07-2008, 04:46 PM
Moderator
davered00ss's Avatar
ebay turbo kit or save for a procharger. You can find a used procharger kit on here for under $3K complete if you look.
Old 09-07-2008, 06:14 PM
LT1Formula007's Avatar
Buy a Honda, gas is too expensive!
I'm just kidding guys, I'm shocked nobody else said something stupid!
IMO, save a little more money & do a H/C/I swap and then do a tune and at least a 6 point cage...
Good Luck with your decision, theres alot you can do with a couple Thousand dollars... Just don't forget with all the new power, you'll need to improve suspension to get the car to hook up out of the hole!
Suspension goes a LONG way...
James
Old 09-07-2008, 08:00 PM
EnfuegoZ28's Avatar
Heads, Cam, and Intake.
Old 09-07-2008, 08:53 PM
TXZ28LS1's Avatar
if i had $2,000
i would go built tranny if its an A4
and a 12 bolt for a M6.
Old 09-07-2008, 09:39 PM
JWG01LS1's Avatar
Thanks to all that helped!
Im gonna go with a cam for sure!!! But getting a honda actually would be smart!! then i can make more radical mods to the Z, not have to worry about it breaking and not being able to make it to work.. thanks
Old 09-10-2008, 10:54 AM
tones2SS's Avatar
Thumbs up
AFR heads, nice cam, and a Kooks exhaust.
GOOD LUCK!!!!
Old 09-12-2008, 05:20 PM
redbadss's Avatar
i would go with suspension since you already have a couple performance mods, $2K can go a long ways in the suspension, plus your car will get a lot more traction making it a "fast street car" like you want, heads and cam won't be the most reliable thing to do if you only have 2K to work with.
Old 09-14-2008, 12:21 AM
Dan Stewart's Avatar
Cam
LT headers and y-pipe (I'm assuming you don't have this as your sig just says "full exhaust" and you need this to get the most of the cam)
Dyno-tune or DIY with HPTuners or EFILive
Old 09-14-2008, 02:46 AM
jsteele90's Avatar
ported 241s, torque arm, and some good drs
Old 09-19-2008, 12:11 AM
DeepV's Avatar
12 bolt!
Old 09-19-2008, 12:33 AM
ReedBooth's Avatar
Save your 2k and hope the world doesn't end.
Old 09-19-2008, 12:54 AM
lemons12's Avatar
full exhaust, cam, ls6, dynotune, and some tires...
explanation.. LTs, and dump them before the axle.. id go with a good sized cam cause it doesnt sound like you will be doing heads soon.. ls6 cause its much cheapers than a 90/90 of course.. tune, and i would buy 2 cheap stock rims and put a good hooking tires on it, wether it be radial or slick and then just switch them when you want to race... also, weight reduction is free to a certain point, take **** off you dont care about. it adds up QUICK and means a lot..
Quick Reply: If it was your car???
