Drive by wire conversion to cable throttle LS1?
Old 11-18-2008, 11:58 AM
69MyWay's Avatar
Default Drive by wire conversion to cable throttle LS1?
I have a 69 Camaro with a LS1 running a 1998 F body computer and cable drive throttle.
I thought I had seen or heard of a way to mount a drive by wire throttle body and pedal on the F body system to convert it.
Is there such an animal?
If not...what are my options to go that route?
Old 11-18-2008, 01:18 PM
jmarsa's Avatar
You need a DBW TB, a TAC module and ETC (electronic throttle pedal). and a PCM that supports DBW. The TAC and the ETC must be matched, meaning from the same vehicle/engine combo. There's lots of posts on the topic.
--JMarsa
Old 11-18-2008, 01:46 PM
69MyWay's Avatar
--JMarsa
That's cool...and I've done that on another project from scratch.
However, I swore I saw a add on conversion some where and my search isn't coming up with it. Maybe I dreamed it???
Old 11-18-2008, 02:10 PM
01badz28's Avatar
I asked the same question in External Engine, and here is what I found:
https://ls1tech.com/forums/generatio...-body-pcm.html
Old 11-18-2008, 02:32 PM
69MyWay's Avatar
I want to make sure I'm reading that thread right. I want to convert my drive by cable car to a drive by wire using the 98 PCM - is that what he is doing...or is he taking a drive by wire motor and wanting to convert to a cable for his older application?????
Old 11-18-2008, 02:34 PM
01badz28's Avatar
Oh, no - I converting a DBW TB into a cable driven TB.
Old 11-18-2008, 02:37 PM
69MyWay's Avatar
Okay...that's what I thought. I'm wanting to do the exact opposite.
Quick Reply: Drive by wire conversion to cable throttle LS1?
