New Pickup Tube Girdle for LSX engines from BRP
BRP Hot Rods is proud to introduce the oil pan girdle for the 00+ GM oil pickup tubes (Patent Pending). This is designed for any pickup tube that has the tab attached to the tube. It has been tested on LH8, CTS-V, Truck and 00+ F-Body oil pans without any issues. Anyone who has changed the oil pan on a LS engine knows how easy it is to pinch the O-Ring and cause a pressure leak in the motor. All GM oil pumps feature two mounting bolts but only use one in all OEM applications. This simple girdle slides over the pickup tube to allow for a secure seal of the o-ring. Getting a solid seal on the pick up tube ensures adequate oil pressure when initially cranking the LS engine and through the engines life.
Shown is the OEM tab seal being broken with a ball point pin. This simple girdle could save your motors life for only 19.95.
Kit includes the BRP oil girdle with aircraft grade bolts and washers.
Call BRP for more info the first batch will be available by the end of December
www.BRPhotrods.com
770-751-0687
www.BRPhotrods.com
770-751-0687
Both bolt holes are tapped on all pumps and all you have to do is slide it over your existing tube and bolt it in place.
Ill look into safety wiring bolts as a option but the first batch of a 100 I have been manufactured will be as the photos show.
Bolt info
6mX20
Zinc Hex
Flanged bolts not in pic but will now be in all production kits.
8.8 grade
Contrast vibration protections in cast iron
The seal was broken with a ball point pen while the tab was bolted down if you look at the photo you can see the OEM bolt locked in place.
Bolt info
6mX20
Zinc Hex
8.8 grade
Bolt info
6mX20
Zinc Hex
8.8 grade
Its not on the site yet ether call or send me a PM and i can shoot out paypal invoices.
We have updated the design and all girdles now shipped with a curved lip for clearance with the timing chains and covers.
Here is a photo, early girdles might need slight smoothing to fit.
Also the bolt on the main cap was tight when the pen lifted up the tab, I have spoke with Mast Motorsports who ran a LS engine with a 5 gallon bucket of oil and the pan removed and the oil pick up tube properly sealed yet it still was squirting oil out where the pen is being shown. Let me know if this is what you’re asking about or feel free to give us a call.
