flipping the fuel rail question?
just to make sure . can I unbolt , unclip and flip the fuel rail, so the feed is on the pass. side on a stock 06 ls2 ? thanks , JOHN
I have flipped it on my LS1.. to put the inlet on the passenger side where my stock location of the hardline is. The FRC would have a problem in there would be no slot / hole for the fuel rail inlet, but nothing you can't fix. Also, your relief valve might be hard to reach.
If you noticed, I did away with the QD by brazing a AN bunt on the end of the Fuel inlet.
