Fuel gauge problems
Fuel gauge problems
I have fitted a complete set of Autometer Pro-Comp UltraLite gauges to my LS1 powered 68 El Camino. Everything seems to work correctly except the fuel gauge. I used the 98 Camaro(the donor car ) tank sender which I fitted to the original El Camino tank. The gauge reads full all of the time. Any ideas?
Unplug the sender from the gauge, does it stay at full? I have the same gauges in mine but am using the stock 68 sender. They are like 90-ohm setups. The 98 ls1 sender is like 50-250ohm or something i think. When i unplug mine my gauge reads full. right now ive got it stuck reading empty when plugged in because for some reason its broken lol
Was the 98' sender unit purchased new? It could be the sender unit itself, I had a similar problem with my gauge registering full and it was due to the unit being faulty.
The gauge you bought most likely has a range of 0-90 ohms like most all GM vehicles before the early 90s. The sending unit in the tank you are using has a resistance range of 70-270 ohms (I think). You either need a sending unit (just the sending unit, not the entire pump assembly it mounts on) from a 93-97 F body or a different gauge.
Re'
Re'
