bbk long tube header question
Old 01-25-2009, 08:40 PM
crazygn's Avatar
Default bbk long tube header question
Iam on a roll with the car and the headers are next, I think i will buy a set of bbk long tubes and weld teh ls1 flange on. My question is what long tubes do i need for the less work. Will the 302 mustang bbk headers work or will it need to be 351 swap mustang headers
Old 01-26-2009, 07:27 PM
crazygn's Avatar
any one know
Old 01-26-2009, 08:18 PM
S10xGN's Avatar
Originally Posted by crazygn
Iam on a roll with the car...
Car... Pretty generic term, you might want to narrow it down some.
Russ
Old 01-26-2009, 09:04 PM
crazygn's Avatar
sorry guys lol car type might help
its a 1989 mustang notch
Old 01-26-2009, 10:47 PM
leonpiper69's Avatar
351 swap headers (302 headers will hit the floor) replace flanges and tweak the number 5 an 7 tubes to clear the steering shaft, if your using a aje k-member dont waste your money on a longer steering shaft like all the fools just lengthen it and it fits fine (cost about one doller).
and if your running a auto you will have to ding the collector to clear the shift linkage on the side of the trans an thats it.
Old 01-27-2009, 08:18 PM
S10xGN's Avatar
Glsd to see someone finally post the necessary "tweaks". This setup fit my Maverick swap w/o any tweaks, but the collector clearance is definitely close on my 200R4. Would you have a part number for the pipe side ball flanges for the collectors?
Russ
Old 01-27-2009, 10:25 PM
Skele4door's Avatar
Just FYI, the Ford exhaust ports are ovalized, so you'll need to use a tube expander to bring them back to round so they'll fit the LS1 flanges. It's not a big deal, but wanted to make sure you were aware of it.
Old 01-28-2009, 12:46 PM
Russ
i just made my own pipes to mate up with the collector. i just belled them out (a friend has a bender machine).
and the part about the flanges being round..... you can cut the headers where they are round an that works ok, i did round mine out (gas pipe flattened worked great, and thanks s10xgn for that tip). by rounding them out you just gain about 3/4 more primary pipe to play with.
but now that someone makes a cheap swap header for this i would have gone that route. for an extra hundred and they drop right in you really cant beat that. the only way i would do the bbk's again is if i got a set for next to nothing like fifty bucks or so. just my .02 cents.
Old 01-31-2009, 05:08 PM
crazygn's Avatar
thanks guys , just picked up a set of mac long tubes today to work with. The pass side fits great still need to check on the other side and buy some flanges
Quick Reply: bbk long tube header question
