2008 Hummer H2 L92 Wiring Diagram + Pinout
The only free E38 info that I know of is here. Its for the vette but it might get you started.
http://www.ls2.com/forums/showthread...hreadid=405808
1 Post
I've got some printouts from a local dealership (for the '08 Yukon/Tahoe series of trucks), but they printed out so small that I'd have to use a flatbed scanner to digitize them, & then see if I could resize them to at least 150% of what they are now...
I have been down that road. You will figure out some things but a lot of things don't match up. I went to alldatadiy.com. twenty some odd dollars for a year subscription. you can print all you want. Or you can go to repairprocedures.com and get one day for free.
1 Post
I checked the parts cross reference and the computer for the Hummer was the same as 08 impala, G6, and 1500/2500 GM trucks. Since the computer is the same, wouldn't the pinouts be the same?
I found an 08 silverado diagram here in the link below. Thoughts?
https://ls1tech.com/forums/pcm-diagn...silverado.html
here is the ECU pin out first connector......................................... ............
Service: 88988931
Description: 73-Way F MX123 34566 Series, Sealed (BK)
Engine Control Module (ECM) X1 Pin
Wire
Circuit
Function
1
0.5 OG/BK
1786
Park/Neutral Signal
2-8
Not Used
9
0.5 L-BU/WH
6311
TCC Brake Signal
10
0.5 PU/WH
1668
HO2S High Signal - Bank 1 Sensor 2
11
0.5 TN/WH
1669
HO2S Low Signal - Bank 1 Sensor 2
12
0.5 OG/BK
380
A/C Refrigerant Pressure Sensor Signal
13
0.5 TN
5514
Low Reference
14-15
Not Used
16
0.5 PU
1589
Fuel Level Sensor Signal - Primary
17
0.5 D-BU
473
High Speed Cooling Fan Relay Control
18
0.5 D-BU
5985
Accessory Wakeup Serial Data
19
0.5 PK
439
Ignition Voltage
20
0.5 RD/WH
440
Battery Positive Voltage
21-22
Not Used
23
0.5 PU
1272
Low Reference
24
0.5 D-GN
890
Fuel Tank Pressure Sensor Signal
25- 26
Not Used
27
0.5 TN
2501
High Speed GMLAN Serial Data Bus -
28
0.5 TN/BK
2500
High Speed GMLAN Serial Data Bus+
29
0.5 D-BU
1161
APP Sensor 1 Signal
30
0.5 BN
1271
Low Reference
31
0.5 TN/BK
6049
Low Reference
32
0.5 L-BU
1162
APP Sensor 2 Signal
33
0.5 GY
2709
5-Volt Reference 1
34
0.5 GY
2700
5-Volt Reference 1
35
Not Used
36
0.5 TN
1274
5-Volt Reference 1
37
0.5 TN
472
IAT Sensor Signal
38
0.5 TN
2760
Low Reference
39-40
Not Used
41
0.5 YE
492
MAF Sensor Signal
42-46
Not Used
47
0.5 PK
1339
Ignition Voltage
48
Not Used
49
0.5 TN
1671
HO2S Low Signal - Bank 2 Sensor 2
50
0.5 D-GN/WH
465
Fuel Pump Relay Control - Primary
51
Not Used
52
0.5 YE/BK
625
Starter Enable Relay Control
53-55
Not Used
56
0.5 WH/BK
1164
5-Volt Reference 2
57
Not Used
58
0.5 D-GN
335
Low Speed Cooling Fan Relay Control
59
0.5 YE
5991
Powertrain Relay Coil Control
60
Not Used
61
0.5 WH
1310
EVAP Canister Vent Solenoid Control
62
Not Used
63
0.5 D-GN/WH
459
A/C Compressor Clutch Relay Control
64
0.5 OG/WH
3223
HO2S Heater Low Control - Bank 2 Sensor 2
65
0.5 GY/WH
3122
HO2S Heater Low Control - Bank 2 Sensor 1
66-67
Not Used
68
0.5 BN/WH
419
MIL Control
69
0.5 PU
1670
HO2S High Signal - Bank 2 Sensor 2
70
Not Used
71
0.5 PU/WH
821
VSS High Signal
72
0.5 L-GN/BK
822
VSS Low Signal
73
3 BK/WH
451
Ground
second connector......................................... .................................................
Description: 80-Way F MX123 Series, Sealed (GY)
Engine Control Module (ECM) X2 Pin
Wire
Circuit
Function
1
Not Used
2
0.5 PU/WH
6270
5-Volt Reference 2
3
0.5 GY
2701
5-Volt Reference 2
4
Not Used
5
0.5 BN
582
TAC Motor Control - 2
6
0.5 YE
581
TAC Motor Control - 1
7
Not Used
8
0.8 D-GN/WH
428
EVAP Canister Purge Solenoid Control
9-11
Not Used
12
0.5 GY/WH
3113
HO2S Heater Low Control - Bank 1 Sensor 1
13
0.5 L-GN
3212
14-15
Not Used
16
0.5 PU
5284
Camshaft Actuator Solenoid Control
17
0.75 D-BU
878
Fuel Injector 8 Control
18
0.75 WH/BK
845
Fuel Injector 5 Control
19
0.75 YE/BK
846
Fuel Injector 6 Control
20
0.75 TN
1744
Fuel Injector 1 Control
21
0.5 YE
410
ECT Sensor Signal
22
0.5 TN
2761
Low Reference
23-25
Not Used
26
0.8 D-BU
496
Knock Sensor 1 Signal
27
0.8 GY
1716
28
Not Used
29
0.8 L-BU
1876
Knock Sensor 2 Signal
30
0.8 GY
2303
31
Not Used
32
0.5 GY
23
Generator Field Duty Cycle Signal
33
Not Used
34
0.5 BK
2755
Low Reference
35
0.5 TN
2752
Low Reference
36
Not Used
37
0.5 L-GN
1745
Fuel Injector 2 Control
38
0.5 RD/BK
1746
Fuel Injector 3 Control
39
0.75 D-BU/RD
844
Fuel Injector 4 Control
40
0.75 BK/OG
877
Fuel Injector 7 Control
41
0.5 GY
2705
5-Volt Reference 1
42
Not Used
43
0.5 GY
2704
5-Volt Reference 1
44
0.5 D-BU
6259
5-Volt Reference 1
45-49
Not Used
50
0.5 TN/WH
331
Oil Pressure Sensor Signal
51
Not Used
52
0.5 TN
2199
Low Reference
53
0.5 OG/BK
469
Low Reference
54-55
Not Used
56
0.5 TN
1664
HO2S Low Signal - Bank 1 Sensor 1
57
0.5 PU/WH
1665
HO2S High Signal - Bank 1 Sensor 1
58
0.5 L-GN
432
MAP Sensor Signal
59
0.5 PU
1666
HO2S High Signal - Bank 2 Sensor 1
60
0.5 TN
1667
HO2S Low Signal - Bank 2 Sensor 1
61
0.5 BN
25
Charge Indicator Control/Charge Indicator Signal
62
Not Used
63
0.5 PU
486
TP Sensor 2 Signal
64
0.5 D-BU/WH
6265
CMP Sensor Signal
65
0.5 D-GN
485
TP Sensor 1 Signal
66
0.5 BN
6266
Low Reference
67
Not Used
68
0.5 WH/BK
6271
CKP Sensor Signal
69
0.5 GY/BK
6272
Low Reference
70
0.5 PU
2121
IC 1 Control
71
0.5 PU/WH
2128
IC 8 Control
72
0.5 OG
2127
IC 7 Control
73
0.5 OG/WH
2122
IC 2 Control
74
0.5 L-BU/WH
2126
IC 6 Control
75
0.5 D-GN
2125
IC 5 Control
76
0.5 D-GN/WH
2124
IC 4 Control
77
0.5 L-BU
2123
IC 3 Control
78
0.5 BN
2129
Low Reference
79
0.5 BN/WH
2130
Low Reference
80
Not Used
Service: 88988931
Wire
Circuit
Function
1
0.5 OG/BK
1786
Park/Neutral Signal
2-8
Not Used
9
0.5 L-BU/WH
6311
TCC Brake Signal
10
0.5 PU/WH
1668
11
0.5 TN/WH
1669
12
0.5 OG/BK
380
13
0.5 TN
5514
Low Reference
14-15
Not Used
16
0.5 PU
1589
17
0.5 D-BU
473
18
0.5 D-BU
5985
19
0.5 PK
439
Ignition Voltage
20
0.5 RD/WH
440
21-22
Not Used
23
0.5 PU
1272
Low Reference
24
0.5 D-GN
890
25- 26
Not Used
27
0.5 TN
2501
28
0.5 TN/BK
2500
29
0.5 D-BU
1161
APP Sensor 1 Signal
30
0.5 BN
1271
Low Reference
31
0.5 TN/BK
6049
Low Reference
32
0.5 L-BU
1162
APP Sensor 2 Signal
33
0.5 GY
2709
5-Volt Reference 1
34
0.5 GY
2700
5-Volt Reference 1
35
Not Used
36
0.5 TN
1274
5-Volt Reference 1
37
0.5 TN
472
IAT Sensor Signal
38
0.5 TN
2760
Low Reference
39-40
Not Used
41
0.5 YE
492
MAF Sensor Signal
42-46
Not Used
47
0.5 PK
1339
Ignition Voltage
48
Not Used
49
0.5 TN
1671
50
0.5 D-GN/WH
465
51
Not Used
52
0.5 YE/BK
625
53-55
Not Used
56
0.5 WH/BK
1164
5-Volt Reference 2
57
Not Used
58
0.5 D-GN
335
59
0.5 YE
5991
60
Not Used
61
0.5 WH
1310
62
Not Used
63
0.5 D-GN/WH
459
64
0.5 OG/WH
3223
65
0.5 GY/WH
3122
66-67
Not Used
68
0.5 BN/WH
419
MIL Control
69
0.5 PU
1670
70
Not Used
71
0.5 PU/WH
821
VSS High Signal
72
0.5 L-GN/BK
822
VSS Low Signal
73
3 BK/WH
451
Ground
Wire
Circuit
Function
1
Not Used
2
0.5 PU/WH
6270
5-Volt Reference 2
3
0.5 GY
2701
5-Volt Reference 2
4
Not Used
5
0.5 BN
582
6
0.5 YE
581
7
Not Used
8
0.8 D-GN/WH
428
9-11
Not Used
12
0.5 GY/WH
3113
13
0.5 L-GN
3212
14-15
Not Used
16
0.5 PU
5284
17
0.75 D-BU
878
18
0.75 WH/BK
845
19
0.75 YE/BK
846
20
0.75 TN
1744
21
0.5 YE
410
ECT Sensor Signal
22
0.5 TN
2761
Low Reference
23-25
Not Used
26
0.8 D-BU
496
27
0.8 GY
1716
28
Not Used
29
0.8 L-BU
1876
30
0.8 GY
2303
31
Not Used
32
0.5 GY
23
33
Not Used
34
0.5 BK
2755
Low Reference
35
0.5 TN
2752
Low Reference
36
Not Used
37
0.5 L-GN
1745
38
0.5 RD/BK
1746
39
0.75 D-BU/RD
844
40
0.75 BK/OG
877
41
0.5 GY
2705
5-Volt Reference 1
42
Not Used
43
0.5 GY
2704
5-Volt Reference 1
44
0.5 D-BU
6259
5-Volt Reference 1
45-49
Not Used
50
0.5 TN/WH
331
51
Not Used
52
0.5 TN
2199
Low Reference
53
0.5 OG/BK
469
Low Reference
54-55
Not Used
56
0.5 TN
1664
57
0.5 PU/WH
1665
58
0.5 L-GN
432
MAP Sensor Signal
59
0.5 PU
1666
60
0.5 TN
1667
61
0.5 BN
25
62
Not Used
63
0.5 PU
486
TP Sensor 2 Signal
64
0.5 D-BU/WH
6265
CMP Sensor Signal
65
0.5 D-GN
485
TP Sensor 1 Signal
66
0.5 BN
6266
Low Reference
67
Not Used
68
0.5 WH/BK
6271
CKP Sensor Signal
69
0.5 GY/BK
6272
Low Reference
70
0.5 PU
2121
IC 1 Control
71
0.5 PU/WH
2128
IC 8 Control
72
0.5 OG
2127
IC 7 Control
73
0.5 OG/WH
2122
IC 2 Control
74
0.5 L-BU/WH
2126
IC 6 Control
75
0.5 D-GN
2125
IC 5 Control
76
0.5 D-GN/WH
2124
IC 4 Control
77
0.5 L-BU
2123
IC 3 Control
78
0.5 BN
2129
Low Reference
79
0.5 BN/WH
2130
Low Reference
80
Not Used
