5.3 engine picture showing sensors
Old 02-02-2009, 09:41 AM
Cj7russ's Avatar
Default 5.3 engine picture showing sensors
I am looking for a picture that will show and identify the sensors on the motor. Ive search the web with no luck.
I know where the CKP and CMP is I am just trying to identfy all the other sensors on the motor.
If not Ill throw a pic up this evening and see if anybody can help me out.
Old 02-02-2009, 10:04 AM
3800RS's Avatar
i have pics of the ls1 if that helps
Old 02-02-2009, 10:35 AM
Cj7russ's Avatar
I am using a truck intake so I dont know if its that much different
Old 02-02-2009, 11:30 AM
ryanvv355's Avatar
MAP is on top of the intake, towards the rear.
Knock sensors are under the intake but the connector is just to the driver side of the MAP sensor on the intake.
Coolant temp is in the front of the driver side cylinder head.
Oil pressure is right next to the Cam sensor.
The cylinder sticking out of the intake right in back of the throttle body is the EVAP purge solenoid.
TPS and IAC are on the throttle body. IAC on top.
MAF and IAT are combined in the MAF.
Alternator connector is right on top.
Then you got coils and injectors
Old 02-02-2009, 12:53 PM
Cj7russ's Avatar
Thanks ryan thats what I was looking for. One question the MAF sensor, I did not get the air tube with the motor and that is where that is located correct?
This is going in a jeep so I will be turning the intake backwards and need to make sure I account for the MAF
Old 02-02-2009, 12:56 PM
ryanvv355's Avatar
Yes the MAF should have been in the intake tract
Old 02-02-2009, 05:40 PM
ForcedInduction's Avatar
Pic 1:
(1) Manifold Absolute Pressure (MAP) sensor
(2) Fuel Pressure Regulator
(3) Positive Crankcase Ventilation (PCV) Valve
(4) Left Bank Ignition Coils
(5) Engine Oil Temperature (EOT) Sensor
(6) Engine Coolant Temperature (ECT) Sensor
(7) Throttle Position (TP) Sensor
(8) Throttle Body
(9) Idle Air Control (IAC) Motor
(10) EVAP Purge Valve
Pic 2
Knock Sensors(under intake)
Pic 3
O2 Sensors
Attached Thumbnails 5.3 engine picture showing sensors-334934.gif   5.3 engine picture showing sensors-198593.gif   5.3 engine picture showing sensors-334918.gif
The following users liked this post:
Z Edge (10-15-2023)
Old 02-08-2009, 05:13 PM
john shea's Avatar
I'm confused #3 is listed as PCV valve. I thought that little piece at the passenger side of the the throttle body was the PCV or are there more than one PCV valve?
Old 03-28-2013, 08:49 AM
jfisher's Avatar
Pretty sure that's just coolant recirculation.
One thing I didn't see was cam position, crank position and oil pressure sensors?
Old 03-28-2013, 09:40 AM
CattleAc's Avatar
#3 is the PCV...the tube you are refering to is a breather/vent tube on the passenger side.
Quick Reply: 5.3 engine picture showing sensors
