Corvette fuel filter adapter
Old 05-03-2009, 10:31 PM
cdwood388's Avatar
Default Corvette fuel filter adapter
Where can i get the quick connect style adapter to use with the corvette style fuel filter for a 6.0 truck engine, it seems to be the cheapest option but i need the adapter or something that will work, any help is appreciated.
Old 05-03-2009, 10:58 PM
TURBO BUICK's Avatar
Default Reply
cdwood, I believe what you are looking for is Dorman part #800-155. Anyplace that carries Dorman products should be able to get it for you. I am getting mine from Summit Racing. Do a search on their website and a picture of it should come up or else go on the Dorman Products website and search for that part number. Hope this helps you.
Rich
Old 05-03-2009, 11:07 PM
waynehartwig's Avatar
I used Russel 640850 and 640860 fittings for the feed/return and I believe the Dorman 800-155 for the fuel filter exit.
12thstreetjunkman's Avatar
Pretty sure all the truck motors have the regulator built into the rail, at least all the ones I have dealt with have. Are you are planning to change intake/rails?
Old 05-04-2009, 10:07 AM
After a certain year they moved from the rail to the tank. I want to say mid year in 06? Mine is an 08 with a returnless system.
Old 05-04-2009, 09:36 PM
Shon Herron's Avatar
I have an 03 6.0 and there is no regulator on the rail.
Old 05-05-2009, 05:51 AM
john 67's Avatar
And russell makes an adaptor to come off the filter / regulator. push connect to an -6 male. part # rus-640940
Old 05-05-2009, 06:46 AM
pmcclelland99's Avatar
I used the Dorman on my Nova, works great!
Old 05-05-2009, 08:57 AM
hookemdevils22's Avatar
i used russell 640853 and 640863 (black versions of what wayne used) on inlet/return, and 640940 on the outlet. i am not pleased at the fact that the inlet/return fittings were a serious pain to get onto the fpr and that they touch, but they do work otherwise.
Quick Reply: Corvette fuel filter adapter
