A body Oil Pan from Pace
Old 05-25-2009, 11:50 AM
70GS/LQ4's Avatar
Default A body Oil Pan from Pace
Anyone used this pan on an "A" body
I have a 70 Buick GS, and I need to order a pan that doesn't have any clearance issue's
Any thought's/recommendations are appreciated
http://paceperformance.com/index.asp...&ProdID=245308
Old 05-25-2009, 03:17 PM
350SS's Avatar
Do a search for LH8 oil pan. Most seem to say that it hangs too low past the crossmember (+ or - 2 in)
Old 05-26-2009, 11:21 AM
70GS/LQ4's Avatar
Thanks, I looked it up, and I dont feel too confortable with that pan now
Old 05-26-2009, 01:42 PM
350SS's Avatar
I used a stock F-body pan with no modifications...just had to move the frame mounts back. It might be different with a Buick. You may want to check out this thread if you haven't already:
https://ls1tech.com/forums/conversio...2-gm-body.html
Old 05-26-2009, 10:22 PM
ryanvv355's Avatar
I am a stickler about trying to get people to not use low oil pans, this is why:
Happened three weeks ago over a speed bump, my trans pan is lower than my oil pan and im glad it is.
Old 05-27-2009, 10:43 AM
70GS/LQ4's Avatar
I like the 72 malibu-(alocker) set-up, using the edelbrock plates, prothane mounts, edelbrock headers, autokraft pan. Sounds like it was a smooth swap.
Old 05-27-2009, 10:49 AM
70GS/LQ4's Avatar
Wow..that blows
Im definately trying to avoid these types of issue's
Old 05-27-2009, 05:00 PM
RYU
RYU's Avatar
Did you have to raise engine some? I'm trying to use the stock F-Body pan also.
(using the Gen I BRP mounts which is the farthest back i've seen so far)
Old 05-27-2009, 06:29 PM
350SS's Avatar
Nope, used energy suspension polyurethane mounts and stock frame mounts moved back far enough for the pan to clear and the engine not hit the firewall.
Old 05-27-2009, 06:37 PM
RYU
RYU's Avatar
That's encouraging! I still hear of folks have trouble with the fitment of the F-Body pan. Not quite there in my build yet.
I'm hoping you don't have steering linkage interference also.
Old 05-28-2009, 01:06 AM
bczee's Avatar
The f-body pan will fit, but very tight, about a 1/2" between the pan and the x-member.. and the passenger side head to the firewall will be about the same 1/2" if you center the engine.
