howmuch h.p. will a msd 6010 handle
Old 08-02-2009, 10:23 AM
baker67nova's Avatar
Default howmuch h.p. will a msd 6010 handle
i have a 408 with et 265 heads,comp solid roller cam,and a f-2 procharger that should be making 20 pounds of boost with the pullies i have on it,and a msd 3bar map sensor.it should be in the 1100-1200 hp range. my question is will the 6010box handle making this much power?if not what should i do?im new to the ls engines so any help would be appreciated.
Old 08-02-2009, 01:19 PM
Pop N Wood's Avatar
The box doesn't really have to handle the power. All it does is provide a 5 volt control signal to the coils.
Since you are boosted you will probably want to upgrade to better coils. The LS1 coils are the weakest of the lot. LS2 coils have 4 times as much spark energy as the LS1 coils, and the truck coils are hotter yet.
The coils have different connectors, so you may have to do some mods depending upon your harness. Read around, there are plenty of write ups on it.
Old 08-02-2009, 01:34 PM
Default 6010
thanks for the input ive read that the 6010box wont work very well in higher rpms.just wanting to make sure this will work for my application
Old 08-02-2009, 02:04 PM
LS1MCSS's Avatar
Here is what the good coils look like, so you will know what to search for.
http://cgi.ebay.com/ebaymotors/GM-LS...4506.m20.l1116
Old 08-03-2009, 05:38 AM
Pop N Wood's Avatar
That's a different question. I hadn't heard that one before. Don't know what to tell you there
MSD has user forums on their web site. You might try asking over there.
Old 08-03-2009, 08:48 AM
what vehicles did the ls2 come out in?and what year. the coils i have now are off of a 06 van 6.0engine will these work?
Old 08-03-2009, 03:50 PM
Pop N Wood's Avatar
This doc has pictures. The truck coils have aluminum cooling fins. Just noticed it also list which vehicles had the better coils
http://www.megamanual.com/seq/coils.htm
The 6010 box has a setting in the software to select between LS1 and LS2 coils. So it supports either one.
Old 08-03-2009, 05:14 PM
Phat69's Avatar
this isn't out yet but it sounds like a good alternitive
http://www.autosportlabs.net/Megajolt2
Megajolt/COP is a Programmable Crank Fired ignition targeted for intelligent coil-on-plug modules or external igniter applications.
Capabilities
Supported configurations
Up to 8 cylinders in true coil-on-plug mode
Up to 12 cylinders in wasted spark mode
10K+ RPM capable
0.1 degree timing resolution
Features
Dual VR Sensor input
Crank Sensor + Cam Angle Sensor input
8 coil driver outputs
Soft and hard rev limit
Designed to work with commodity OEM sensors and coil packs
Initial support for 36-1 trigger wheel; other trigger wheel configurations to follow
up to 16x16 ignition map with linear interpolation
Dual, on the fly switchable ignition map support
4 User defined digital outputs
3 analog input channels
TPS, Temperature and Aux
Ignition correction for Temperature and Aux
Provision for on-board MAP sensor
On-board expansion for knock sensor module
32 bit 48Mz ARM processor
USB programming interface
Old 08-03-2009, 05:55 PM
Thumbs up 6010 box
thanks for the information guys that megamanual.com website has a lot of info i needed thanks again. whats the most horsepower anyone is making that you guys know of using the 6010box?just curious
Old 08-03-2009, 10:17 PM
S10xGN's Avatar
Originally Posted by Pop N Wood
...The 6010 box has a setting in the software to select between LS1 and LS2 coils. So it supports either one.
Pop, I'm not familiar with that setting, where's it located? I have version 3.19...
Russ
Old 08-04-2009, 05:31 AM
Pop N Wood's Avatar
Russ
When you hook up a laptop to program the box it is on one of the menu pages. I am not sure which one, been a while since I programmed the box. It is on the same menu that sets rev limits and selects between a 1 or 3 bar MAP sensor.
Guess I should be careful, I have a 6012 box made for an LS2. But I would imagine the software is the same for the 6010.
Quick Reply: howmuch h.p. will a msd 6010 handle
