Using Transdapt Motor mount part# 4592 on A G_body/LQ4 swap
Old 08-23-2009, 12:52 PM
G'D_UPLQ4's Avatar
Question Using Transdapt Motor mount part# 4592 on A G_body/LQ4 swap
Is this part an adapter for you stock sbc motor mounts to mount the LQ4?
Or is it the actual mounts themselves?
Please chime in...I need some help fellas?
Old 08-23-2009, 01:11 PM
Shon Herron's Avatar
This is what you get with that kit
Old 08-23-2009, 01:43 PM
G'D_UPLQ4's Avatar
is that everything i need because it doesnt answer my question..
Old 08-23-2009, 02:59 PM
DiabloFormula's Avatar
The kit only comes with the plates for the LS block and the brackets that attach to the plate you have to buy your own mounts that go on the k-member, which I'm in the process of finding out which ones they are.
Old 08-23-2009, 03:59 PM
Jimbo1367's Avatar
I thought with these type of plate mounts, you need the stock engine mount and then swap frame mounts side-to-side.
I am tring to learn too. So can someone chime in? I originally planned on just going with BRP Hotrods conversion for a 2nd gen F-body. But it looks like they upped their prices. I am affraid to know how high they will raise by the time I finally snag a LQ4 or LQ9
Jim
Old 08-23-2009, 04:02 PM
G'D_UPLQ4's Avatar
Jim
i think you're right there was a gentleman on here ls2monte who said he used these adaptors with his lq4/ssmonte swap
Old 08-23-2009, 06:39 PM
topher455's Avatar
Moroso 62630 frane pads are what I used. You will meed to clearance them a little since they are used with solid mounts though.
Old 08-24-2009, 12:37 AM
Rat Chevelle's Avatar
Hey, That would be everything you need if you had an older car like my 70 Chevelle, which is an A-body. While you could get the moroso mounts and all that, the easiest route for you would be to simply unbolt the mounts (solid shell style) from your SBC and bolt these to the adapters which are bolted to the engine.
You would have the sandwich type mounts left over, but you do not need these since the damping rubber is attached to the frame mount on G-bodies.
AsI said that should be the easiest and most inexpensive way of mounting your engine. You will end up with the engine to transmission flange about 1.250" anead of the original location, and you will need to move the transmission mount accordingly if you are keeping the same drivetrain.
Therefore an even cheaper solution would include a different kind of mount, like the Hooker style, then you can reuse your transmission, and even driveshaft.
Make sure you use a spacer and flexplate from a 4L80E equipped 6.0, you can find these at junkyards for about $20, or at GM for about $60.
Old 08-24-2009, 06:27 AM
transdapt has just the plates #4572 without the rubber mount.
Old 08-24-2009, 08:09 AM
Marky522's Avatar
I have a set of the plates from Transdapt the exact ones pictured, I have only mounted them once, but they were wrong for what i needed you can have them for $30 shipped.
Mark
Old 08-24-2009, 09:35 AM
topher455's Avatar
Lots of guys just use the plates with their original style mounts. I didnt like the way they looked thats why I used the other ones. Also transdapt offers a 1" setback mount plate which is what I used. Forgot to mention it earlier.
Old 08-24-2009, 11:14 AM
G'D_UPLQ4's Avatar
Mark
do you have the original box with them...can you post a pic of them...If you still have them in a week when i get paid ill take em off your hands...
Old 09-04-2009, 06:17 PM
Jimbo1367's Avatar
pics......?
Quick Reply: Using Transdapt Motor mount part# 4592 on A G_body/LQ4 swap
