Looking into doin 5.3 or 4.8 s10, need answers
Old 08-27-2009, 12:16 AM
2XR95Z28's Avatar
Default Looking into doin 5.3 or 4.8 s10, need answers
So i've been tossing around the idea of doing a BUDGET 4.8 or 5.3 swap into an s10. I just want something i can beat the crap out of, cut up, run nitrious and not really care.
Like mentioned this would have to be budget, i know with budget comes cheaper parts and not as much reliability but i just want to build something i can take to that track and run decent numbers, low 12's high 11's or so? faster would be cooler but i understand its rough on a budget.
I can get a roller s10 for around 400 bucks so that is covered...
5.3 for $400 or 4.8 for $250ish (from local guy) is the 5.3 worth the extra $$? It will be a cam only motor and i would like to do a small shot (100 or 150) Will these motors be able to handle that?
Planning on doing a victor jr with a carb and keeping the coils and using the MSD box to control those...
so looking at...
truck-400
motor-250-400 depending on 4.8 or 5.3
cam and springs-400-600
intake- 270
carb- 350
MSD box- 320
tranny-300ish (th400)
thats $3000ish total...
i would still need a fuel cell (used) fuel pump, fuel lines, headers, and motor mounts...
are hedmen the only people who make long tube ls headers for s10s? those things are very expensive... Only thing that is really killing my budget here...
i know i could cut some more corners here if i can find some used parts but that is all luck if i can find used parts at the time...
Anything else i'm missing or leaving out? any suggestions to make this cheaper? I really dunno if i can swing the 3 g's and really want to do this...
Thanks!
Old 08-27-2009, 08:38 AM
MeanYellowZ's Avatar
Since there is a good chance the S-10 you start with (87 and up) will have been fuel injected from the factory, you may as well keep it injected to save money. If the engine comes complete with injection on it, you just need a harness and then just stick an EP-381 fuel pump or a Walbro 255 in the tank and you are done. This will save you the cost of the MSD box (300) carb intake (250) and carb (100 used to 350 new)
Also check my sticky at the top of this section for more budget ideas....I just finished another 5.3 swap in less than two weeks and I haven't figured the exact dollars yet, but Im thinking Im going to come in around 1200 total for this one.
Besides, you have the cheap EFI swap guru in town, Joe
Old 08-27-2009, 10:43 AM
2XR95Z28's Avatar
Oh i was planning on having a little chat with the local LS swap guru haha
So i'd be looking at 1200 with the LS1 intake, fuel rails and all that? or is that with the truck intake still? i could deal with either.
Then i would need a th400 correct?
What are we looking at for motor mounts and that fun stuff?
I might make a stop over today to ask some questions.
Old 08-27-2009, 12:12 PM
Ill be doing a 6.0 swap into an S10 in the next couple weeks so i will have fresh parts/ numbers for you to think about. the one I just finished was with truck manifold/ rails/ wiring...which is easy...but ugly
Old 08-27-2009, 12:17 PM
2XR95Z28's Avatar
Alright, i'll probably end up doing a 5.3, with a truck manifold rails and wiring for now. I really don't care about looks as this is just something to put together quick and beat the **** out of and not care lol. Care if i stop over today to shoot the ****?
Old 08-27-2009, 12:32 PM
feel free....I should be around most of the day
Old 08-27-2009, 03:17 PM
01WS6/tamu's Avatar
Budget and s10 do not go in the same sentence for LS swaps. I was very frugal only buying what I had to to make mine work and work well and it turned out to be quite expensive. It's done now and runs great knocks down 25-27 wa 6.0 without fail. Took quite a while to do it will not be a quick swap either
Old 08-27-2009, 09:27 PM
ls3s10's Avatar
i have done this swap in 3 s10s its a royal pain and nothing fits just to let ya know. advice is buy sanderson headers and jags that run mounts . the motor sits lower and driveline angle is best. i have pics of every mod done to mine so just ask me . fyi i had over 4k in swap with stock motor it adds up fast
Old 08-27-2009, 10:02 PM
orange88ls1s-dime's Avatar
i just took my 5.3 1996 s10 for the maiden voyage today ran awesome walked all over a dakota R/T i mean bad had to let up a bit so the guy woulldnt commit suicide from low self esteem hehe i have 3000$ canadian into my truck and i still have to do body and paint not bad for a good running V8 s10
Old 08-28-2009, 12:26 AM
01WS6/tamu's Avatar
Few pics of mine. Haven't updated in a long time got a ton more now that it's done
http://s253.photobucket.com/albums/hh62/01ws6tamu/
I've really enjoyed stompin *** and sippin gas n my little lq9 powered dime. Really hurts some egos when you give some room then reel em in and whoop their ***.
Old 08-28-2009, 01:07 AM
2XR95Z28's Avatar
well i plan on getting the car shop inc motor mounts and their headers. Truck wont have PS or anything, just crank pulley, WP, and alt so that will all be simplified.
here is the price break down i have taken from Meanyellowz (LS swap genious, and is local so he is close for advice)
5.3 motor- 450 used
Th350 or 400- 200 used
Harness & fuse box- 150
Headers and motor mounts- 340 new
Russell fuel rail fittings, 5/16 & 3/8 - 6AN $28 new
255lph pump- 120 new
GM flexplate spacer and bolts $60 new
S&P coolant temp adapter 3/8NPT-12mm $24 new
o2 sensor bungs (2) $8 new
junkyard ECM $40 used
o2 sensors # 13193 Bosch (2) $100 new
Delphi MAF $94 new
PCV valve $5 new
Spectre air filter $25 new
Upper radiator hose $22 new
Used Camaro radiator $40
Used Camaro e-fans $60
Fuel filter (factory) $7
Fuel line & -6AN hose ends (4) $80 new
adapter from metric o-rings to 6 AN (2) $22 new
Total- 1875
so that is around 1900 for a complete ready to run 5.3 th400 with car shop inc shorty headers.... I will have around 400 in a rolling chassis s10.... so $2500ish for running truck...
as you can see most of those parts are new on there and maybe could save a bit here and there if i can find some deals on used stuff....
Old 08-28-2009, 01:25 AM
01WS6/tamu's Avatar
You are heading in the right direction for sure. Cool thing about these trucks is that they lend themselves really well for being purpose built. I built mine for long term reliability, fast little sleeper, looks like you are heading towards a driveable racer. So yep somewhere in the sub 4K range by the time everything is done and you'll have a fast fun little ride.
Old 08-28-2009, 07:05 AM
vandejr's Avatar
dont forget the cam---250-350
better springs---------100-200
stall to match---------200-500.
im doing the same thing and around the 2000 range. but all ls1 accesories and carshopinc swap parts.
Old 08-28-2009, 09:49 AM
2XR95Z28's Avatar
Well for right now its going to be a stock motor. If i have money later i'll yank it out and throw a cam and springs in it. and as far as a stall i should be able to pick up a th400 stall dirt cheap around here locally.
Quick Reply: Looking into doin 5.3 or 4.8 s10, need answers
