HELP!!!!!! ls1 to th400
Old 10-23-2009, 02:26 AM
RNation0001's Avatar
Default HELP!!!!!! ls1 to th400
ok im about to do a lsx swap into a 67 camaro, im ordering all the stuff at the same time pretty much. im goin to mate it to a th400, i ordered the crankshaft spacer. now can i use the converter from my th400?? i have a b&m torque master 2000 i had in a th350. will this work or will i have to get a different converter or flexplate. i really need some input any help is greatly appreciated
Old 10-23-2009, 11:32 AM
84BuCkeTOfStEeL's Avatar
If you're using the curved ls1 flexplate then you need to oblong the holes on the ls1 flexplate. Reason is the bolt spacing is different 298mm vs 300mm i believe??? and wont match up with your torque convertor. Its been done before and there are alot of threads on here about it. Search function is your friend.
Old 10-23-2009, 01:00 PM
i tried a search but didnt find anything. any help on what to type in the search?
Old 10-23-2009, 02:03 PM
6point7s14's Avatar
Look at the stickies in the auto trans forum
Old 10-23-2009, 02:16 PM
blk96406's Avatar
Default link
Here is the link:
https://ls1tech.com/forums/automatic...questions.html
Old 10-23-2009, 05:48 PM
rtpassini's Avatar
i talked to TCI and they said all I need is their flexplate (didnt say which one)
I have a th400 from a pontiac that i will be using for an LQ4
The only other modification I would need is if i had a large or small hole torque converter. (which I dont know) either way they said they have a TC that will work for me...
Old 10-23-2009, 06:59 PM
cacmanjr's Avatar
I don't believe that a BOP transmission has the bolt holes in the right place. I think it has to be a Chevy trans.
Old 10-24-2009, 05:16 AM
jbsjunk's Avatar
They don't. Well, the bottom two line up but the rest don't. Unless a adapter plate is used.
Old 10-24-2009, 08:24 AM
rtpassini's Avatar
do they make an adapter plate. or should i just get a chevy tranny
Old 10-24-2009, 08:56 AM
jbsjunk's Avatar
If your trans is good, have the internals swapped in a Chevy case. Won't have adapters to mess with and it may play into a spacing issue with the LS flexplate if the adapter was used.
Old 10-24-2009, 11:51 AM
forcd ind's Avatar
all this flywheel stuff is so confusing, lol
a stock 350-400 converter has a snout that is to short to reg into a stock
LS flywheel-the 4L80E trans used the same dim of a 350-400 conv., as far as reach, so GM used a spacer (.400) bet the crank and flywheel to extend the crank to the converter, and used a flat flywheel to keep the same dim as far as the starter mesh as the curved flywheel
if not using a spacer between the crank/flywheel, then a (diff., no bolt holes)spacer needs to be used between the flywheel and converter(earlier truck cranks had a longer rear section, no spacer, but we will assume not many out there now, lol)
when i installed my stroker engine, i swapped out my fact. 4L80E spacer and flywheel for a TCI one (SFI rated) it was also flat, i assumed it took the old 4l80e spacer since it was flat, but it didnt, was thicker with a spacer bolted to it, and the ring gear teeth were at the correct dim.-but now my 4L80E converters (same for 350-400) snout didnt reach the crank to reg, but there was a spacer with the flywheel, but the insts. said dont use the spacer if using an LS engine?????? well, the spacer is just what i needed to match up and reg. the crank/snout-i assume they were thinking you would be using the 4l60e with a long snout, i even called TCI with no help orig.
the flywheel was even listed for a 4l80e, go fig-but it all works now-i had a 400 in it before i switched to the 4l80E, so it all uses the same dims.
Old 10-26-2009, 06:07 AM
wajouba's Avatar
I have a th400 but it came with a th350 torque converter is that normal?
are the hole positions the same for the Th400 and the TH350? (Converter wise) cause when I tired it on my 98 LS1 Camaro's flywheel they didn't bolt up? there was a difference... (I know I need a spacer I have it, I know I need the longer bolts I got the ARP ones, Im asking about the holes pattern not bell housing, but the holes that go frm torque converter to Flywheel)
So my question is would I need to get a th400 torque converter or should I get a flywheel that fits my th350...
on a side note: I liked the idea of a th350 torque cause its smaller so less rotation mass, don't you think?
Old 10-26-2009, 06:24 AM
gold98Z28's Avatar
read post #2
Old 10-26-2009, 06:40 AM
wajouba's Avatar
ok so is the th350 torque the same as the th400? are there benefits from using the th350? less weight?
Old 10-27-2009, 04:05 AM
wajouba's Avatar
Default is this a normal difference?
Check this picture guys is this the normal difference you guys are talking about?
Thanks
Old 10-27-2009, 07:49 AM
gofastwclass's Avatar
Thanks
That is the curved Gen III flexplate. To make that work with a 1997 or older transmission you need spacer PN 12563532 ($37) and six longer bolts PN 12563533 ($25).
I have seen a few early truck engines with a crank snout .400 longer (sticks out from the back of the block) while the normal Gen III cranks are flush with the rear seal. Those engines don't need this adapter or bolts and are easy to spot with the engine away from the transmission.
Old 10-27-2009, 08:32 AM
wajouba's Avatar
already bought both of those bro, my problem was just if the th350 torque which is pictured behind that flywheel of my 98 camaro, has the same pattern of the th400 bolt... so is the 298mm 300mm difference the same? thats my question thanks!
(I was thinking of sticking to the th350 torque on the th400 for less rotating mass...)
Old 10-27-2009, 08:33 AM
wajouba's Avatar
cause as u can see the bolt don't align perfectly..
Old 10-27-2009, 01:03 PM
68 TT's Avatar
The converter will work on both the T-400 and the T-350 but the bolt spacing is different. There are typically both bolt patterns on Gen-I flexplates for this reason.
You may have a T-400 bolt pattern converter on the T-350.
I don't know but maybe the smaller T-350 bolt pattern matches up with the smaller 298 mm spacing used with the 4L60E.
Old 10-27-2009, 02:31 PM
wajouba's Avatar
not sure bro... but all I know is someone told me that its a th350 converter, on a th400, is there anywhere u can link me to show me how can I fix my flexplate to make it fit this converter?
Quick Reply: HELP!!!!!! ls1 to th400
