Turbo LQ9 in a 70 Buick GS
Old 01-10-2010, 07:55 PM
javajoe79's Avatar
Default Turbo LQ9 in a 70 Buick GS
This is a car I am doing for a guy here in Nashville. Now I have messed with my fair share of LSx variants but I know some of you guys are just chock full of all sorts of random LSx info. One weird thing with this engine is that the way the throttle lever is positioned on the throttle body, it wants the cable to come up from below and along the front of the motor. This engine came from an 02 Escalade. Has anyone used this throttle body before? Before I weld an elbow to it, I would like to hear from you guys. Mainly, what cable did you use, or do I need to fab something to make a universal cable work? Here are some pics of the build so far.
javajoe79's Avatar
Old 01-10-2010, 08:28 PM
skinumback's Avatar
I have a LQ9 DBY TB and computer if your interested?
Old 01-10-2010, 10:05 PM
javajoe79's Avatar
Well the customer supplied a harness and computer so I got that covered. Is the LQ9 normally drive by wire? I wonder what this throttle body is from?
Old 01-10-2010, 10:26 PM
71 chevy's Avatar
nice setup. i did not know the truck headers would fit an a body facing down. did you have to do any mods to make that happen?
Old 01-11-2010, 12:51 AM
350SS's Avatar
That throttle body is from a gen 1 vortec motor, not a gen III which is why the throttle lever is pointing the wrong direction and there is no lip to clamp the intake tube to. They used threaded extensions on the three bolts that the intake piping bolted to.
Old 01-11-2010, 01:31 AM
DrededSS's Avatar
Pics of the rest of the car?
Old 01-11-2010, 02:04 AM
garys 68's Avatar
I've got an 02 escalade LQ9, it's DBW. I thought they all were. Is there an IAC on your setup? If not, wrong TB.
Old 01-11-2010, 08:25 AM
javajoe79's Avatar
Ok thanks. That is helpful. I have a camaro throttle body that has the lever in the right orientation. I may just use that instead.
Thanks Yeah I replaced the steering rag joint with a low profile flaming river unit and cut off the flanges as you can see. I welded a bend with a Vband to the DS and just the Vband to the PS. They fit nicely. The car also does not have power steering so that helped a little in fitting the DS pipe under the PS bracket.
I'll have some more soon.
Old 01-11-2010, 08:31 AM
Tricked-Out-Toy's Avatar
This is a great little build I just wish he went with a S480 haha either way itll def hit his goals with the 75. didnt you have pics of the fuel system!?
Old 01-12-2010, 09:27 AM
javajoe79's Avatar
I don't have any more pics. I think he might have took some of the fuel system. I should have the car back on the lift in the next few days so I will get some more pics.
Old 01-12-2010, 10:10 AM
Sweet, you sumped his stock tank right?
Old 01-12-2010, 01:06 PM
javajoe79's Avatar
Yeah I did. He also supplied dual walbros and a nice harness for them.
Old 01-12-2010, 02:37 PM
jfg455's Avatar
Carefull. Stock F body T bodies are smaller than LQ4/LQ9 T bodies. One is 68mm? and the other is 70mm. I can't remeber the exact diamentions.
Old 01-12-2010, 07:42 PM
javajoe79's Avatar
This throttle body I have is 75 mm. Hmm... I wonder what it is from? I thought it was a camaro but I am not sure. Anyways he is planning on using a different manifold and throttle body, later on with his built engine so this will work for now.
Old 01-12-2010, 09:21 PM
crosstraining's Avatar
I thought LQ9's weren't ideal for turbo's because of the higher compression?? Let me if this is not the case, as I'm building an LQ9 for my 72 Nova right now. It's not too late to add some boost
Old 01-12-2010, 10:28 PM
javajoe79's Avatar
Yeah well the plan is low boost for now until he builds the motor, then turn it up
Old 01-14-2010, 11:31 AM
jfg455's Avatar
My mistake. The F body ones are 75mm and the LQ4/LQ9 throttle bodies are 80mm. This is for the cable driven units. I just found the info while looking for something else.
Old 01-14-2010, 11:32 AM
jfg455's Avatar
LQ9's are 10:1 factory as opposed to 9:1 for the LQ4's. But, the LQ9's have stronger rods. You can still turbo it but you have to tune and watch for knock.
Old 01-15-2010, 04:00 PM
buick_lsx's Avatar
The new throttle body on loan from chris, much larger than the origional
large 2 pass heat exchanger with dual fans for the a2w setup
New guage panel going in the dash
Quick Reply: Turbo LQ9 in a 70 Buick GS
