How painless is a painless harness for a lsx swap
I have a swb 85 GMC and was thinking of doing a 6.0 ls swap but i don't like to mess with the elctrical much i was wondering if theres much i have to do to make this work .ive seen other threads on sawps but are not thet specific on the wiring side .any help?
i went with a street and performance kit when a put the 414 in my firebird. all you needed was to plug it up to the motor give it power and ground, and i had to get a fuel pump relay.
I used the Painless kit. I'm sure there are other good options, but I have a hard time understanding how any could be *better* than Painless! Everything is exactly the right length and clearly labeled. They have really well developed instruction manuals, and they have excellent phone support, too.
If I do another LS1 swap, I'm going with Painless again.
Cheers,
Dean
Cheers,
Dean
just pull up a chair and read. I was in the same boat. I didnt want to mess with all the wiring but i just started to take the harness apart and it wasnt that bad at all. I ended up using a 94 lt1 camaro fuel/relay box too. Im not going to lie, im proud i did the wiring my self.
you say you already have a harness. Are you trying to modify a used harness or have you purchased one already?
With a little more information...like the year/make of your engine and transmission I can recommend a Painless harness that will make your life a lot easier than trying to modify a used harness. Right now we (Painless Performance Products) have specials that could save you a lot of money..
Mike
Unless you need a new harness because yours is damaged or building a show car. I suggest you re-work your stock harness. Schematics are readily available. If you trust your soldering skills, go for it. You can buy a cam and swap headers for the price of one of their aftermarket harnesses.
TB Integrated Fuel Injection & Chassis Harness
I'm going to take you up on that offer and see how much you can save me. I had previously spoken to Jack at Painless, he recommended harness #60608 at a retail cost of $1995 ( but only $1416 if I got it from Jegs or Summit), seemed a little steep to me, maybe you can help. PM being sent.
Mike
Mike
Mike-
Right now is a GREAT time to take advantage of several of our promotional programs.
With the #60608 your getting a TB Integrated Fuel Injection & Chassis Harness in one kit with everything you need to get you on the road.
Purchase your #60608 from any Painless retailer before March 31, 2010 and fill out this rebate form and we will send you $100 bucks back.
Here is a link to the rebate form.
http://www.painlessperformance.com/2010BenFranklin.pdf
And to sweeten the deal we will RE-flash your ECM for free. That will save you up to $300 more.
Go to our wesite and register with our TARP program to get the rest of the details.
Feel free to check out our Facebook site. Become a fan and upload a picture of your project.
We are excited about seeing our customers rides!
http://www.facebook.com/pages/Painle...3464822?ref=nf
Thanks Mike. Let me know if there is anything else we can do.
I personally have used a Painless harness for my LT1 swap. They're expensive but the quality is top notch, even better than the factory imo, but then I went with a reworked factory harness for my LS1 swap and the company who did it was at least 50% cheaper than Painless and the quality was also good with easy to follow instructions. What I see is that Painless is offering you a complete harness for the vehicle and engine which is good if the vehicle is old and in need of new wiring but its going to be expensive to find a reputable shop to install all of that wiring. I can easily see a shop charging you a minimum 10 hours worth of work or more. At this point its all about how much you want to spend or save.
