91 mustang ls swap aluminum driveshaft???
Old 03-21-2010, 05:58 PM
Mustang605's Avatar
Default 91 mustang ls swap aluminum driveshaft???
I have an aluminum driveshaft from my t5 is there a way for me to have this modified to fit my 4l60e?
Old 03-21-2010, 05:59 PM
livefast1's Avatar
buy a new yoke make sure you get the right spline and a 1330 u joint.
Old 03-21-2010, 06:48 PM
Mustang605's Avatar
do i have to cut the driveshaft?
Old 03-22-2010, 01:49 PM
Mustang605's Avatar
ttt ttt
Old 03-22-2010, 03:41 PM
GlennNo50's Avatar
It depends on where your motor ended up. My brother has an alminum drive shaft and it is about an inch too long with the motor where it is. If the motor was an inch further forward it would fit with nothing but the yoke/u joint change.
Edit..
We are using a slightly modified 5.0 tubular k-member and home built motor mounts, i have no information as to our motor position compared to the AJE k-member/motor mount combo.
Old 03-22-2010, 08:48 PM
Mustang605's Avatar
ok...preciate it...I'm in the middle of debating between an 4l60e now & a th350
Old 03-23-2010, 11:21 AM
livefast1's Avatar
i have a lq4/th350 in my 01 gt and all i had to do was change the yoke but i know that doesn't help you out much.
Old 03-23-2010, 01:20 PM
Mustang605's Avatar
how's your fuel mileage...that's the only thing I'm afraid of with the th350 I'll be losing overdrive
Quick Reply: 91 mustang ls swap aluminum driveshaft???
