Will a truck pcm fun electric fans?
Old 03-26-2010, 07:31 PM
millwright1999's Avatar
Default Will a truck pcm fun electric fans?
I am doing research for my swap this summer. I have a LQ4 with computer, I will be modifying a truck harness(from a different truck) Does the truck computer have the ability to run electric fans? I know I will have to add relays, but will the computer tell the relay when to turn on or do I have to use a seperate sensor. If the computer does turn the relay on or off, what pin of what connector? The pin out I have does not show me, but seveal are blank.
Old 03-26-2010, 08:45 PM
sawzall wielding director
G-Body's Avatar
Blue connector pin 42 will put out a ground output to run the fans. This is the low speed fan control in the PCM. pin 33 on the red connector would be the high speed, but it does not work on the truck operating system, so you will have to run the fans off of the low speed output only and do a single speed fan setup.
Old 03-26-2010, 09:36 PM
what is a single speed fan setup??
Old 03-26-2010, 10:00 PM
is that where you wire the fans in siries for one spped and parallel for the other speed? I know I read that the other night, but can not find it now?
Old 03-26-2010, 10:01 PM
dec010974's Avatar
Default electric fans
hello millwright1999. from what i hear, the fans can be programmed to turn and off, from the pcm sending a ground signal to the relays. the vendor i used said they programmed my pcm for that operation, but it didnt work. so i ran the fans off the ignition. i like it better 'cause i know when the ignition is on, the fans r on. miami fl, heat is a killer. im running a setup of a 5.3/4l60e swapped in a chevy c10
Old 03-27-2010, 12:20 AM
CODE4LS1's Avatar
My PCM is out of a '00 GMC Sierra and both my fans are commanded by PCM w/no issues.
Old 03-27-2010, 08:41 AM
Old Geezer's Avatar
Default Same here...
My 05/LQ4/Hummer pcm has controls for both fans...
Engine had a mech fan, changed to dual electrics.
Old 03-28-2010, 10:30 PM
G-Body's Avatar
Seems to work for some people but not others. The high speed fan control on most of the trucks was used from the factory for something A/C related (air recirculation door IIRC?) and I have read that for more than a couple people it would not control the fans, that it only put out a pulsed ground. But I never tried mine, I have the fans set up as a single speed.
Old 07-25-2011, 07:24 PM
lrazer's Avatar
is there a way to change the 2nd fan output from a pulsed ground so the 2nd fan can be used?
Old 07-25-2011, 07:58 PM
MillsMotorvation's Avatar
I have a 2002 LQ4 PCM, and I sent it to LT1swap, and He has the Hi, and Low working Blue42/Red33.
Old 07-25-2011, 08:50 PM
chuckd71's Avatar
Same here, and each comes on at a different temp.
Old 07-25-2011, 09:18 PM
lrazer's Avatar
ive got hp tuner and have the fans turned on but all i im getting on the fan 2 output is a pulsed ground signal when activated not a constant ground like fan 1
Old 07-26-2011, 08:10 PM
Dang my low speed fans stop working!
Old 08-07-2011, 11:25 PM
lrazer's Avatar
Anyone?
Old 08-07-2011, 11:42 PM
G-Body's Avatar
Did you go to the system>A/C tab in HPT and set the recirc option to fan #2?
Quick Reply: Will a truck pcm fun electric fans?
