Fram 3506 oil filter doesnt fit
Old 03-27-2010, 04:31 PM
onefastrx7turbo's Avatar
Default Fram 3506 oil filter doesnt fit
Hi everyone, I did some searching but came up with nothing on this. I have a brand new Fbody oil pan from gmpartsdirect. I bought the cheap fram PH3506 oil filter for startup and break in but it doesnt fit! I removed the oil filter fitting and sure enough, the boss is too large for the filter. This is the second filter I have tried. If I turn the boss around, the threads which thread into the oil pan thread into the filter. Did GM put the wrong boss on this pan?
Old 03-27-2010, 06:41 PM
Jimbo1367's Avatar
try a different brand filter. (GM)
Old 03-27-2010, 10:39 PM
Quagmeyer's Avatar
The newer pans have a different filter. Just mention that you need the newer filter at the parts store, and they should be able to take care of you.
Old 03-28-2010, 01:46 AM
iansane's Avatar
If you HAVE to use a fram filter, use the ph10060. As said, the newer pans (even if they're a fbody replacement or something) all have the screw in nut for a PF48 Delco filter as opposed to the older PF46. The fram cross reference is a ph10060.
Old 03-28-2010, 03:06 AM
ahh that would explain it! I dont have to use a fram, just thought it would be ok for break in? then changed in about 500 miles? This explains why two different filters didnt work. This board rocks...thanks guys
Old 03-28-2010, 08:37 AM
Pocket's Avatar
My new pan also didnt fit the stock filters. I salvaged the fitting from the truck pan I was discarding
Old 03-28-2010, 06:32 PM
rockytopper's Avatar
This demon hit my swap too.
Old 09-04-2010, 10:02 PM
jwill_20's Avatar
I too became a victim...thanks for lack of info GM, BTW this pan is for a 98-02 fbody but requires a 08 and up ls3 oil filter lol
Old 09-05-2010, 12:52 PM
Jimbo1367's Avatar
I wish GMPP would put in a card/sheet stating the recommended filter. I too ran into this with a new GMPP pan kit. The PF48 has a built in pressure relief too.
Old 09-06-2010, 12:20 AM
iansane's Avatar
The nature of modifying cars...
Old 09-06-2010, 06:49 AM
Old Geezer's Avatar
A cheapo filter, just when the engine likely to be running with the most dirt in it??
Old 09-06-2010, 09:18 AM
tennerv8's Avatar
Frams are junk anyway. Use AC Delco PF48.
Old 09-06-2010, 09:20 AM
gofastwclass's Avatar
"But, but, but... their commercials say..."
The "old" Gen III pans use the standard 13/16" threaded filters while the "new" pans use metric 22mm fittings.
When looking for a filter tell them you need one for a 2004 2500HD truck with a 6.0 (22mm metric fitting). Then make sure to keep the part number for this, the belt and whatever else you may have changed handy on the list you keep in the glove box. ...You do keep all this on a list in the glove box don't you?
Old 09-07-2010, 12:26 AM
iansane's Avatar
Originally Posted by tennerv8
Frams are junk anyway. Use AC Delco PF47.
You mean a pf48? Or a pf46?
Old 09-07-2010, 01:06 AM
Try using a Wix 57060, it has the 22mm x 1.5 metric thread you need.
Old 09-07-2010, 06:51 PM
buddyholly's Avatar
Add me to the list of victims here. Filled my new filter full of oil before testing it of course. New F body pan and had to use the filter off the pan from the L76 engine.
Old 09-07-2010, 08:23 PM
chevyboy91188's Avatar
i ran into this problem too using the muscle car swap kit, since it says it was modeled after the lh8 (i think, w/e the hummer h3 pan is) i simply figured the h3 alpha filter would work, and it did
Old 09-08-2010, 12:17 PM
Klimaxx's Avatar
this got me on my street and performance pan...DOH...good thing i was able to use the filter (i had already filled with oil) on my trans am
Old 09-23-2010, 06:41 AM
2 SSlow's Avatar
Wow, I'm glad i'm not the only one. This bullshit kept me from starting my car for the first time last night. THANKS FOR THE HEADS UP, GM.......ugh.
Old 11-02-2016, 03:43 PM
BLNLS1/RX7's Avatar
Had the very same thing happen to me on my swap.
Quick Reply: Fram 3506 oil filter doesnt fit
