radiator hoses that fit chevelle radiator
1968 chevelle. LY6 (l92 style water pump) does anyone know a set of radiator hoses that will fit? i need upper and lower
Measure the openings (OD) and take a hanger and bend them around to see the shape needed, then look here and get as close to what you need as you can.
http://www.mvreader.com/multiview/da...bgDimHoses=1&l
You can also get a small piece of the hose ( 3" or so) and use a SS tube for the curves and or straight parts, seen that before.
Hope this help dude!
Go to Autozone and get either part# XL-183 or XL-185. Both are about $9 each........ I have a 69 Chevelle... I have the XL-183 on but you will have to trim it at the waterpump...... These will work if you are using a water pump with the pump spout facing forward....... If the spout is facing up toward the passenger side the XL-183 you prob will not have to cut....
The lower hose I used 17" flex hose(you could get away with 18")
My radiator is Summit's 80457 for a big block Chevy....I used this when I had my BBC......
The water pump for the upper hose was around(these are ballpark) 1 1/4(pump) and 1 1/2(radiator)
For the flex hose I got it 1 1/2 on each end(pump/radiator)
this is the water pump i have:
http://cgi.ebay.com/ebaymotors/07-09...item3354ea23f0
will the hoses you are referring to work with that pump?
I hate to say it but trial and error.... I measure it first, then took the old hose of the GTO and went to Autozone, asked the guy if I could size em up and pulled and matched as I walked down the racks..... Until I found one, then after I found em, I came back here and Thunderstruck and had already found the XL-185.....lol But I guess I can state claim to the XL 183.....
If they don't work take em back, I had to take 2 back.... I bought 3-4 of them that I thought would fit....
the problem i have with the hoses you stated is you more than likely don't have the same water pump as me. you probably have the truck one with the curved upper portion, or a car pump. neither of the hoses that work for those situations will work for me.
