What is the most HP out of a carbed 6.0L with factory heads
What is the most HP a person can make with a stock 6.0L short block and the best factory LSx heads??
Has to be done with a carb and no N2O.
What I hope is that I can use a stock 6.0 shortblock, add a pair of 799 or 243 heads, swap the cam, add a Super Victor intake and a carb to produce as much HP as I can to reach into the 10's with a 3100lb 1970 camaro.
Not sure exactly how to get there but that is what I want to do if it is possible without having to flycut the pistons or use N2O, I'm not sure it can even be done but I would like to try. So any help would be greatly appreciated.
Is there an easy way to tell me how to fly cut the pistons while they are still in the block??
Just wondering just how that is done and how you know how much to cut and when to stop cutting
How much does your car weigh??
Ok, so after reading that link I have a question for you guys who have already had the pistons flycut. How many thousands did you guys flycut?
What size valves come factory in 799 and 243 heads?
