Another LSx in my nova.....
Old 05-08-2010, 09:42 PM
twin74s's Avatar
Default Another LSx in my nova.....
WEll after my car sitting for a lil over a year i dealed into a new drivetrain for it.
Details are as follows.
07 6 liter with 7k miles, has L92's on it.
Liberty Faceplatted T56 Spec 3+ clutch, Spec billet steel flywheel.
9" rear Stange 31 spline Pro race axles, ??? gears, detroit locker.
XXR 18x8.5's and 18x9.5's 275/40R18 front 295/35/18 BFG brag radial rear
Coil overs on all four corners
Custom Torque arm rear suspension
Mini tubbed
Work is coming along slowly but i should have it together and driving in the next 2 months. Heres a few pics of the progress.
Old 05-10-2010, 03:27 PM
6D9
6D9's Avatar
Sick looking build!
Old 05-10-2010, 04:16 PM
slownova73's Avatar
love the stance and the color scheme!! You have done everything i want to do to mine suspension wise!
now only if i could sell my LT1 and do an LS2 swap!
subscribed!
Old 05-10-2010, 04:34 PM
Chicago TDP's Avatar
What tire and rim combo is on the car in the pic?
Old 05-13-2010, 08:46 PM
twin74s's Avatar
They are 6 1/4 backspace. Also my rear is narrower than stock.
Old 05-14-2010, 08:19 AM
Don't the front wheels rub on the fender and then on the frame when the wheel is cranked all the way (either left or right) ?
Old 05-16-2010, 03:53 PM
twin74s's Avatar
No, With the 275's on the front it doesn't rub anywhere.
Old 05-16-2010, 05:48 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
I used to have a faceplated T56 in my RX7. Good stuff!
Andrew
Old 05-19-2010, 08:07 PM
twin74s's Avatar
Andrew
Did you street drive it much? If so how was it?
Old 05-20-2010, 01:26 PM
It was my daily driver. If you search under my name in the manual transmission forum you can read my whole write up.
Andrew
Old 05-20-2010, 07:13 PM
twin74s's Avatar
Andrew
Just read thru that... Thanks for the link. I actually bought mine from Fitz98ta in that thread after his car got wrecked.
Can't wait to get to drive this thing.
Old 06-16-2010, 08:32 PM
twin74s's Avatar
Finally did some more work this last weekend.
Painted Frame, suspension parts, firewall and dash.
Installed rod bolts.
Re-installed engine/trans in car.
Old 06-16-2010, 10:27 PM
hcb1700's Avatar
That's one good looking Nova.
Old 06-25-2010, 08:39 AM
twin74s's Avatar
Well finally some more progress. Got the drivers side header all tacked together last night...Should have the other one tonight.
Old 06-26-2010, 09:13 AM
twin74s's Avatar
Old 06-26-2010, 08:06 PM
1dirtybird's Avatar
Which mounts are those? I would like a set
Also how much did you trim off the truck pan to clear the steering linkage?
I have a ctsV pan but havnt decided which one i want to hack up for my swap.
Eric
Old 06-28-2010, 08:55 AM
twin74s's Avatar
Eric
I built these mounts myself. THey put they engine closer to the firewall than everyone else's.
I only shortened my pan height wise. It clears the steering stuff as the engine is farther back.. Ill get a picture of it when i go back out to the shop.
Old 06-28-2010, 10:33 AM
1dirtybird's Avatar
Those are very nice, indeed. Would you be willing to share the deminsions? I can make them. I will be using the truck intake for now as it shouldnt hurt much with boost. It would be great no to have to cut the oil pan, thats for sure. I would like the easy part to be getting the engine in so i can started on the hot pipes.
I am running 6 cyl springs in the front and had clearance enough for a SBC 7 qt pan. I was thinking id even have enough room for the truck pan.
Old 07-07-2010, 09:24 PM
twin74s's Avatar
Ordered my cam yesterday from texas speed. 229 236 .624 .615. Also ordered the rest of my gauges, mufflers shifter handle and a bunch of other odds and ends.
Old 07-07-2010, 09:26 PM
twin74s's Avatar
The truck pan hangs low. I trimmed about 1.5 inch of the bottom. It is the lowest part on my car. I don't see anyway you could run it without shortening it.
Quick Reply: Another LSx in my nova.....
