Fuel Composition Sensor (FCS)
Donor rig is an 03 Tahoe with Flex Fuel capability, and I'd like to retain that if possible. So here goes:
I received the FCS when I got my engine, harness, and PCM but it was only connected via the harness. Which tube is the inlet?
I've had the rear O2 sensors deleted from my PCM, do I need to use the After-Cat O2 sensors when running E85?
I just Googled this topic and it seems that either fitting can be used as the feed and the return. This is because the sensor is able to determine what kind of fuel is passing thru. I'm assuming that GM had some extra fittings in place on the donor vehicle that would've come in hand for the swap if you wanted a factory looking install.
