Is my 2001 6.0 an lq4 or lq9 ?-from a pickup
Old 08-15-2010, 07:17 PM
john 67's Avatar
Default Is my 2001 6.0 an lq4 or lq9 ?-from a pickup
I have a 2001 6.0 iron block from a pickup complete takeout,I did a search and it seems the only way to tell is to look into the cylinder to see what type piston it is .Is there any other way to tell ? I will be installing this into my 66 biscayne .Also any input to add 100 hp would be helpfull .JOHN
Old 08-15-2010, 07:23 PM
1_bad94Camaro's Avatar
you can also tell by the 8th diget of the vin. I cant remember which letter means which motor. the pistons is the easiest way to check.
Old 08-15-2010, 07:38 PM
69LT1Bird's Avatar
8th digit of VIN.
LQ4 = U
LQ9 = N
Old 08-15-2010, 08:05 PM
-TheBandit-'s Avatar
How about running a compression check? The LQ9 should generate higher psi than an LQ4 based on the increased CR.
Old 08-15-2010, 08:15 PM
Bullitt4110's Avatar
I was able to look through the spark plug hole on mine with a flash light and seen the dish in the piston to determine that it is a LQ4.
Old 08-15-2010, 08:55 PM
GMCtrk's Avatar
LQ4. LQ9 production didn't begin until 2002 model year.
Old 08-15-2010, 10:21 PM
john 67's Avatar
Thanks for the info, I cant find the vin , there is a vortec cover on the motor,
Old 08-16-2010, 07:40 AM
Old Geezer's Avatar
Default Look at
the dr side, rear of the block... Should be marked w/ a laser etching.
Quick Reply: Is my 2001 6.0 an lq4 or lq9 ?-from a pickup
