VATS module
Old 08-21-2010, 02:26 PM
eagz28's Avatar
Default VATS module
I am in the middle of swapping a 99 ls1 into a 93 camaro. I am trying to bypass the VATS system but can't find any info on where the VATS module is. I'm thinking the BCM but don't want to rip it apart until I know for sure. Could anyone help me out, specifically with the location of the VATS resistor? Thanks.
Old 08-22-2010, 07:14 AM
poconojoe's Avatar
In 93 the module should still be up behind the dash towards the middle and its a bitch to get out. The resister is in the key
Old 08-22-2010, 10:09 AM
eagz28's Avatar
i used a 99 wiring harness and looking for vats, is it in bcm or pcm ?
Old 08-22-2010, 10:13 AM
poconojoe's Avatar
The PCM is looking for a signal from the BCM
Old 08-22-2010, 10:10 PM
the_merv's Avatar
LS1Tech 10 Year
PCM looks for a signal from the Vats..it's that blue wire labeled Fuel Enable.
As long as you have it tuned out you will be fine, just ground that yellow/black stripe wire that's on the starter relay.
The following users liked this post:
LeaVictoria (07-18-2024)
Quick Reply: VATS module
