Need help! 69 Camaro/Procharger
I have a 69 Camaro that will be a Ls2/6 speed car and I have plans on using a Procharger. I have seen the kit from procharger to fit in the 67-69 Fbodys but I really dont like the location of the blower in regards to the inlet location. For those that have not seen, it is similar to the 04-06 GTO/2010 Camaro kit mounted high on the driver side.
I love the location of the head unit on the 97-04 Corvette kit. Does anybody have experience with trying to use this kit in a 67-69 Fbody? Will it work or not???
Thanks
Troy
Thanks
Troy
Thanks
Troy
Thanks
Troy
I used there swap bracket kit and it works very well. Get with Bob at Brute Speed he can hook you up.
The GTO bracket will not work see photo below, head unit will hit the upper control arm mount.
LS1Tech Sponsor
I have seen the Corvette drive used in a 1969 camaro but it leaves little to no room for the air inlet on the procharger, here is the best option for swap in to muscle cars. My nova uses the same sub frame.
Thanks Jason, I agree that the system you have is the best way to go on these cars. Here is the link to the D-1SC system complete with the intercooler. Give me a call for an even lower price. http://shop.brutespeed.com/ATI-1LS10...S100-D1SCI.htm
Thanks! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Kick *** ride you have! My two concerns with the kit on your car is the air inlet. I will be using a C5 booster and master in my Camaro, and I just dont know how to fit all that crap in that small space. I also like the idea of the air inlet drawing fresh air instead of air right on top of the engine.
Thanks again!
Troy
Thanks! Bob
Thanks! Bob
Bob, thanks for your input as well. I have talked to you in the past about this subject. Im just trying to look at every option and get everything planed out so im two steps ahead. I have purchased from you before and I will be back when my project gets to this point once the $$$$$ are ready.
Troy
LS1Tech Sponsor
Troy
Troy
__________________
Bob, what kind of mods to the radiator were you thinking of? I think im going to use the edelbrock mounts and headers. I have also thought of using the hooker mounts which would shove the engine as far back as possible to give me a little more room.
Troy
The cost is all most the same, I ran the numbers both ways several times, I did the majority of the work on my car my self and the cost was marginal. I like the fact you get free power from a turbo, but the noise and attention factor out way the turbo. IMO
