Tach Adapter in 1972 Firebird
Old 10-30-2010, 09:58 PM
mred's Avatar
Question Tach Adapter in 1972 Firebird
i have done everything per the instructions and i cant get a reading from the gray wire.
i am getting voltage in all the right places minus the ground and gray wire.
i have replaced both Autometer Tach and Tach Adapter,nothing....
(The most common wire color used for power to the coils is Pink. Follow the Pink power wire away from the coils & connector to where it is most comfortable to work with(Auto Meter suggests 2”-6” away), then cut this wire in half. Repeat this on the other side of the engine as well. Run the power-side Pinks (left & right) together and attach to the solid Red of the adapter. Next run the coil-side Pinks (left & right) together and hook to the Red/Green of the Adapter. Ground the Black wire of the adapter to a suitable chassis ground. The Gray wire of the adapter is your new tachometer signal output.
Old 10-31-2010, 09:34 AM
mred's Avatar
all this knowledge and no one knows,lol...
i guess i will have to use the feed off the ecm and run my own wire.
so much for running a autometer tach and tach adapter
Old 11-01-2010, 10:15 AM
thunderstruck507's Avatar
Your post isn't very clear. You talking about the gray wire on an aftermarket tach harness or the wire from the pcm that controls tach signal?
Old 11-01-2010, 07:36 PM
mred's Avatar
says it in the post.
Old 11-04-2010, 09:36 AM
wrea398's Avatar
Default RE Tach adapter
I just did an electric autometer tach in an LS7 Monte carlo. Use the wire from the ECM to the signal wire on the tach. Put a 1K resistor between the ECM signal wire and the 12V tach source wire close to the tach. No adapter needed. Works fine.
Old 11-06-2010, 10:00 PM
sum guy's Avatar
I wired my truck straight from the computor to tach and later added said resistor with no noticeable changes. Keep it simple.
Old 11-07-2010, 01:03 PM
69cutlassrkt's Avatar
this is the way to go
Old 11-11-2010, 08:51 PM
mred's Avatar
thanks for the input guys.
your suggestions is what we decided,but the after market wiring harness added the wrong color wire at terminal/pin GREEN 38.
so we had to do some double checking.
all is well now,.
thanks
Ed
Quick Reply: Tach Adapter in 1972 Firebird
