Frame Notching 67-69 Camaro Firebird 68-74 Nova
Old 11-01-2010, 12:41 PM
-TheBandit-'s Avatar
Default Frame Notching 67-69 Camaro Firebird 68-74 Nova
Please post up an pictures and links/info you have of notching your frame for clearance in a 1st gen Camaro/Firebird or 3rd gen Nova. Notch could be for an ac compressor, alternator, oilpan or ?
Here is one example of notching the frame to clear a low mount ac compressor:
http://mcspeed.homestead.com/69_Cama...urrection.html
Old 11-01-2010, 01:22 PM
Another example. Not sure, but you may have to be logged into lat-g for this to work.
http://www.pro-touring.com/forum/sho...a-LS1&p=610358
Old 11-01-2010, 01:27 PM
Good pictures here if you are a lat-g member
http://www.lateral-g.net/forums/atta...8&d=1236383265
http://www.lateral-g.net/forums/atta...0&d=1236383265
http://www.lateral-g.net/forums/atta...9&d=1236383265
You may have to be logged in to lateral-g.net for these to work:
Old 11-01-2010, 02:37 PM
Steve68's Avatar
This is what I 'm waiting on my VA kit for,
I posted in my thread the my parts guy went to SEMA, so maybe next week, but the pic on lateral G may work where I dont need a bracket to do the compressor mock up, may just cut and weld,
Thanks for the pics!!!
Old 11-01-2010, 03:49 PM
SamHatco's Avatar
Default BRP Kit
Here is a picture of the BRP a/c frame notch kit.
Price is $25.00 for the piece...you notch the frame and weld in.
http://www.brphotrods.com/mm5/mercha...gory_Code=CNV1
Old 11-01-2010, 06:55 PM
Steve68's Avatar
very nice, thanks for posting, looks like a really simple way to do it!
Old 11-02-2010, 10:28 AM
I contacted the builder from the above frame notch to get more info on his compressor mounting and here was his response. He sent some more pictures of his fabricated brackets which I am posting. This is great stuff!
The compressor is a Zexell
Zexell 504-524 1/H/11, TRU-58616
the idler pulleys are ITM 60288, Napa NBHT 42011, NTP 95216, CLOYES 95216
the belt is 6K938, Gates K060938, Goodyear 4060940
These will work if you are running the stock accessories from a camaro. my motor is from a 98 camaro. I had to move the compressor forward to run on the same belt as the other acccessories. If you need anything else at all let me know
Attached Thumbnails Frame Notching 67-69 Camaro Firebird 68-74 Nova-ac-brackets-compressor.jpg   Frame Notching 67-69 Camaro Firebird 68-74 Nova-ac-compressor-02.jpg   Frame Notching 67-69 Camaro Firebird 68-74 Nova-ac-compressor-04.jpg   Frame Notching 67-69 Camaro Firebird 68-74 Nova-ac-compressor-05.jpg   Frame Notching 67-69 Camaro Firebird 68-74 Nova-frame-ac-work-04.jpg
The following users liked this post:
Motown 454 (12-02-2021)
Old 11-02-2010, 02:36 PM
Steve68's Avatar
I like the frame notch, but I'm going to stay with the 2 belts,
Just talked to the guys at BRP, great bunch, mines on the way!
Old 11-02-2010, 03:00 PM
When you say you are going to stick with the 2 belts, do you mean you plan to run the compressor off the 4 groove section of the crank? If so, are you sure putting the compressor that far back wont interfere with the motor mount? Are you using BRP's mounts?
Old 11-02-2010, 04:04 PM
Steve68's Avatar
You know I could be totally wrong, maybe teh VA kits moves everything foward and it runs off the main belt, I'll have to check the VA site,
Been 3 long day,s 12 hrs, up at 1am to work at 2am home at 3:30, I'll have to refresh my memory at the VA site,
Old 11-03-2010, 02:58 PM
bczee's Avatar
If you want to use the oem AC compressor, You cannot use any of the standard or 1" set back type of plates.. (S&P, ATS, Edelbrock, Hooker, etc).. as the plate comes into contact with the AC Compressor. I have checked that out already. That is way many who use those type of plates have to go with Aftermarket AC kits and brackets. Relocating the Compressor up top.
You have to mount your engine with the way BRP does. Using Early BRP style of plates and relocating the Frame Stands. Notching is required also.
There new kit is suppose to be able to mount the OEM compressor also.
Old 11-03-2010, 03:10 PM
Steve68's Avatar
I know the VA kit has a Sanden 508, I was going to use a stock one but both systems work on variable pressure so supposedly the VA kit will kill the OEM compressor, but I've heard different also,
Old 11-22-2010, 03:31 PM
Bump for more info. I am getting close to putting mine under the knife.
Old 11-22-2010, 04:51 PM
Chevy406's Avatar
I did a little cross-member notch for my Moroso oil pan. I cut three sides, pushed down the top of the cross member, and then closed it back up with ½"x½" angle.
Old 11-22-2010, 05:04 PM
Steve68's Avatar
NIce,
I got my piece to weld in, been working on the DD and the mini tub, measure twice cut once,
Old 03-22-2011, 01:36 PM
btt for more
Old 03-22-2011, 04:36 PM
Steve68's Avatar
Little blurry, better one to come!!!
Old 03-22-2011, 04:51 PM
thenova70ss's Avatar
Do you need to Notch the Frame for the alternator on the 1st gen Camaro/Firebird or 3rd gen Nova's? I have been looking at my car and it don't look like need to on my 1972 Nova but it looks like the alternator will be close to the frame.
Old 03-22-2011, 04:57 PM
That depends on what alternator, accessory spacing, and engine mounting location you're using.
Old 01-26-2012, 02:16 PM
Here is a notch I did on the driver's side to low mount a large DR44 truck alternator. The bottom plate was radiused by bending it around a pole in my garage. It is 3-1/2" deep from the front face with a 3-1/2" radius and the lower surface is even with the top of the lower control arm bolt access hole.
Here is a shot of the interior to show how the rear plate connects down to the lower part of the frame.
Quick Reply: Frame Notching 67-69 Camaro Firebird 68-74 Nova
