Dual Electric Fans---Two Relays...Or Three Relays?
Old 01-24-2011, 04:36 PM
LS1GMCTruck's Avatar
Question Dual Electric Fans---Two Relays...Or Three Relays?
2001 F-Body Computer, with 2001 Dual electric fans. Should they be wired using two relays, or three? And why? (Only one of my fans come on.)Thanks
Old 01-24-2011, 04:39 PM
ebk06's Avatar
they can be wired either way. the 2 relay way only allows the fans to operate at one speed. the 3 relay way they run at two speeds.
Old 01-24-2011, 07:02 PM
aknovaman's Avatar
Wink
2 relay setup operates one high speed fan and one low speed fan.
3 relay operates both fans electrically in series for low speed and one for high speed.
Old 01-25-2011, 07:17 AM
bjamick's Avatar
Old 01-25-2011, 11:13 AM
Andy1's Avatar
I like the three relay method, as two fans at low speed (run in series) are quieter than one fan at high speed (two relay low method), IMO.
Andy1
Old 01-25-2011, 03:44 PM
Thanks for the great replies everyone. I have mine wired via two relays & the second fan never comes on, ever...even with the A/C turned on. What could be my problem, or what do I need to do? thanks
Old 01-25-2011, 04:37 PM
aknovaman's Avatar
Be sure your settings in the PCM file are correct. If you get a stock camaro file and compare you will likely find a difference.
Old 01-26-2011, 01:10 PM
MillsMotorvation's Avatar
I use the 3relay setup, and Dodge fans.
Quick Reply: Dual Electric Fans---Two Relays...Or Three Relays?
