LS1 to TH400 trans. What flywheel to use???
I read three articles from "experts", on this subject, wrote down all part numbers given, the only one that was in all three was the spacer---, get in touch with the GM powertrain people, your local dealer can get you the 800 number, they gave me the correct numbers, with a case file number so that if you have an issue wwith their info, you have some evidence you spoke to their "experts", if you need to return anything. I am doing the same T-4oo/gearvendors setup behind an LS2
I decided against the muncie since I have to go in for my left knee to be bolted together again. Sucks gettin old! Plus, I got a super deal on the new TCI trans and I have all the automatic shifters and stuff. Muncie M20 is for sale though. Came out of a 68 Camaro.
The fact that you actually did it puts you at their level, most if not all writers follow what someone else tells them..and thats not a spacer to index the converter in the picture????
As in one part I meant you only order the 1 part # from GM. Some say to order the flexplate AND the spacer. The spacer and bolts are all included in the box.
That was the # the GM tech gave me for the flexpate. Also 12563532 for the spacer , and 14088764 for the bolts. Makes ya wonder, they should be the first on the correct info???? Next time I am in town, will hit the local dealer with these numbers and see what happens.
