About to start piecing together the build. LSX Notch
Old 02-02-2011, 02:01 AM
itsslow98's Avatar
Default About to start piecing together the build. LSX Notch
Another LS1/t56 notchback. Grabbing a 4 cylinder coupe when i find one but would like to get most of the parts here before i find the car. Here is what ive put together parts wise and questions that I couldnt find after reading and reading and reading and searching. If you think anything needs to be added please add it and comment on anything. This is a budget build in a home garage and possibly a shop so Ill have a good amount of tools and help. Thanks, ive answered about 500 questions by reading the stickies and searching.
LSX Fox Build List
- LS1 with 4l60e or T56…………..$4,300 (with pedals, shifter, hydraulics, etc
- AJE K member………………….$349
- AJE Trans X member…………..$159
- Speartech Wiring harness……...$450
- Custom Driveshaft……………...$500?
- Radiator and fans….……………$free
- MS3 Cam Kit…………………...$700
- Fuel Pump……………………....$125
- Corvette return style regulator..$50? Or is this not needed for a fox?
- 8.8 Rear………………………….$300
- Brakes……………………………$80
- Tires……………………………...$400
- Odds and ends…………………...$1,000
- Subframe connectors..........$150
Questions
- How does the VSS affect the motor swap into a fox?
- Does the t56 shifter line up with the stock mustang center console?
- Is the clutch safety switch integrated in the stock fbody pedal assembly?
Old 02-02-2011, 02:31 AM
whore-hey's Avatar
when I was thinking about doing it my friend who did his gave me these links.
http://forums.stangnet.com/showthread.php?t=635318
http://forums.stangnet.com/showthread.php?t=656581
Old 02-02-2011, 02:33 AM
itsslow98's Avatar
Thank you, hadnt come across them so im reading them now. So far I have favorited these links for research when im doing the assembly.
https://ls1tech.com/forums/conversio...me-help-3.html
https://ls1tech.com/forums/conversio...questions.html
https://ls1tech.com/forums/conversio...onversion.html
https://ls1tech.com/forums/conversio...wheel-use.html
https://ls1tech.com/forums/conversio...de-1500-a.html
Old 02-02-2011, 03:18 AM
brian_rs/ss's Avatar
good **** man, i am considering doing a sn95 lqx, th400 build. however i wont be able to start till the end of the year so i'll be following this for sure.
Old 02-02-2011, 11:44 AM
RATBOX's Avatar
Didn't see sub frame connectors in there, those are a must.
Old 02-02-2011, 03:32 PM
itsslow98's Avatar
Thanks, added.
Old 02-02-2011, 05:12 PM
ebk06's Avatar
I'd budget more for brakes. You gonna want sn95 booster and m/c. You can find them cheap used but I've never liked used brake parts. My brake swap cost me about $500 with all new ss brake lines and hose and pbr front brakes. Would have been more but I got the hoses and complete front brakes half price.
Old 02-02-2011, 09:46 PM
itsslow98's Avatar
Thanks, ill most likely be looking for a rear with 5 lugs and discs already or buying a roller with it all done if its possible.
I found the answer for the first question about the security system, tune or use a little box to get rid of the VATS.
Old 02-03-2011, 03:19 AM
RATBOX's Avatar
Ya speartech can kill the VATS for you, that is assuming he's doing a harness for you. He'll be doing mine, fo sho.
Old 02-03-2011, 04:06 AM
itsslow98's Avatar
Yep they are on my list to do the harness. Is it better to just buy a full harness from them or send one to have them modify? I like the 450 over 700.
Old 02-03-2011, 12:53 PM
RATBOX's Avatar
Well, if you can get a harness for less than $250, then buying one and sending it to them would be the way to go. If not, then I'd just buy from him. My LS1 came complete with a harness, so obviously I'm sending mine to him here in the near future.
Old 02-03-2011, 04:37 PM
sfen78's Avatar
Are you gonna buy headers or make em?
Old 02-03-2011, 08:42 PM
ebk06's Avatar
Send them yours. They do a great job and have a quick turn around.
Heres my stock harness from an 04 GTO.
Heres some pics of it when i got it back from speartech. They did a great job at labeling everything and it came with some detailed instructions on what to wire up and how.
Heres a close up of all the wires that went inside the car along with the pcm connectors. I was told the GTO harness was a bit longer than most so i hav plenty of room to mount it inside my mustang.
Speartech can do the VATS disabling but if you are doing any internal mods to the engine see if your tuner can do it and include it in the charge when you get the car tuned. It may end up being a little cheaper than way. Any tuner can disable VATS.
Old 02-04-2011, 02:39 AM
itsslow98's Avatar
Awesoem thanks a ton guys that wiring post is a huge help. I had found them a while back while researching and fully planned on having them rework a harness. Great to hear good feedback. And yes, I plan to do a big cam and ls6 intake and kooks long tubes while its out i figure it be easier.
Another question- Seen a few things about pedals. If i get a 6 speed fbody pedal assembly is that easier to use? ANd would I have to modify the stock master? My buddy who did an LS1 RX7 purchased a wilwood master to use without modding since it had a shorter shaft.
Old 02-04-2011, 02:54 AM
RATBOX's Avatar
I'm doing a TH400, but plan on building a second fox with a 6-speed and from what I can tell it seems the way to go is a pedal assembly from a turbocoupe.
Old 02-04-2011, 04:53 AM
itsslow98's Avatar
Yep 87-88 only now i gotta find one which seems to be a task.
Old 02-04-2011, 02:59 PM
Tim94gt's Avatar
You could also use the Mcleod kit.
https://ls1tech.com/forums/conversio...ot-easier.html
It's a little pricey, but it's an option.
I'm also in the planning stage of my 94 Mustang Lsx/T56 swap. I can't wait to get started, I should be picking up an Lq4 in a few weeks when the tax return arrives.
Old 02-04-2011, 03:42 PM
LilJayV10's Avatar
I was talking to a friend of mine today about doing a LS swap into a notch back.
I think it would be a pretty damn sweet setup. I am going to spend the rest of the afternoon reading the swap threads.
Old 02-05-2011, 12:24 AM
RATBOX's Avatar
XR7 Cougars of that vintage would also work, I believe.
Old 02-05-2011, 08:31 AM
ebk06's Avatar
Heres another write up about swapping in a fox. The clutch isnt very hard especially if you have a welder. I mainly opted for an A4 after reading this because I didnt want someone else doing work on my car and i didnt want to have to have the car towed to a shop while i sit there and explain to them what needs to be done. I have a write up going on on here that should be updated todat or tomorrow. I hoping to fire up the car for the first time this weekend.
http://forums.corral.net/forums/show....php?t=1164954
Quick Reply: About to start piecing together the build. LSX Notch
