Any1 use Molex XRC bulkhead system
I seen this in a SuperChevy mag recently.
http://www.superchevy.com/technical/.../photo_07.html
It looks simular to DSE's setup.
http://www.detroitspeed.com/projects...vyII-pg-1.html
DSE pics # 68 & 69. (6 rows up from the bottom; 2nd and 3rd pics from the left.)
Have put together thousands of different Molex connectors. They are known for simplifying installations and helping with wire management.
Your hard drive power connector is even a molex connector.
Like Tim says, expensive and work well.
Thanks Gofirstclass!!!
what is "expensive" ??? ball park figure?
thanks
thanks
We use those on our airborne radars.
McMaster Carr sells those connectors, prices don't look too outrageous. The 13 amp per connector rating would prevent them from being used for everything on a car. Probably need to mix these with just a couple higher amp rated connectors.
MMC's web site seems to have plenty of other options.
http://www.mcmaster.com/#pin-and-soc...ectors/=ax4jdi
Waytek has a bunch of different options too
http://order.waytekwire.com/scategory2/m50/320/550/
Ooh. Just found this one
http://www.americanautowire.com/cata...dingAccess.pdf
